70 cutlass radiator support or center
i need a clean 70 cutlass center support, the part the grill bolts to, will take the whole support if is clean thanks i am located in south new jersey
A 71-72 grille support will work,but is slightly different.The 70 grille support has 4 tapped holes for the grilles.The 71-72 grille support has 2 tapped holes and 2 regular holes,so you would need to use a nut & bolt for the lower holes when using a 71-72 grille support on a 70.
There are also two different styles for 70.One with a single square opening on the top,and the other with two square openings on the top. The latch hook was on the opposite side,on the 70 hoods,and sometime during production,they maust have figured that they were going to put the hook on the other side for 71,so they started punching two holes out.
So,technically,there are 3 different styles of grille supports for 70-72. Early 70,late 70,and 71-72.
Now i a going to take this over and say that i need a Full core support that is in a very good condition as i will use it for when i restore the body. So surface rust at the most i guess. Please send pics to sicto1983@gmail.com and a price with shipping to 78245. Looking for a 70 one for my Rallye
jensenracing77
Jan 25, 2018 04:16 PM
helm42
May 31, 2011 06:43 PM
