1970 W30 water pump
Old Nov 1, 2013 | 01:01 PM
cdoering's Avatar
1970 W30 water pump
I need a water pump for my 1970 W30 (must have X code on pump) with A/C.
Chris 314-495-1700
Old Nov 1, 2013 | 10:05 PM
507OLDS's Avatar
I have 5 of them. I will check the dates.
Old Nov 4, 2013 | 02:25 PM
cdoering's Avatar
Did you check the water pumps. Let me know how much
Old Jul 14, 2014 | 03:30 PM
cdoering's Avatar
The water pump you sold me was for a non A/C W-30. I just had it installed on my rebuilt engine and was told its wrong and for a non A/C car. I need to send the other one back for a replacement or refund my $250. You did tell me you would guarantee the waterpump. I need this done ASAP
Chris 314-495-1700
thanks
Old Jul 14, 2014 | 04:08 PM
cdoering's Avatar
This is Brian Trick correct?
Old Jul 14, 2014 | 04:57 PM
Octania's Avatar
Chris,
My info [based on paper copy of factory PN Manual printed 1972] says the "X" water pump is for
1968-69 442 TH400 perf. Eng.; 1968-69 V8 w/ C.A.C., HDC, O.A.I.; 1970 442 F85 V8 CAC HDC, O.A.I.; 1970 5400, 6400, 6600, 98. PN 230900
CAC = Car Air Conditioning
So, it appears to me that this item IS for "with A/C" and/or "with HDC" applications, and whoever told you "it's wrong and for a non A/C car" is, uhm, misinformed.
Perhaps you have incorrect pulleys that preclude the use of the correct pump?
Chris
Old Jul 14, 2014 | 05:00 PM
jensenracing77's Avatar
X2. The X pump you have should be correct for all 70 W-30 cars.
Old Jul 15, 2014 | 09:40 AM
Octania's Avatar
Is that because W30 mandated the HDC option, therefore the "X" WP?
Old Jul 16, 2014 | 09:52 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I believe that is correct.
X-treme duty.
The 5.7 pump was used on AC cars as well as non ac cars. 68-71
Old Jul 17, 2014 | 09:46 AM
Octania's Avatar
Ah, so all W30's that year should wear the "X" water pump, but many other cars ALSO got the X water pump. W30's is a subset of X-Pump engines.
"This is my "X" Water Pump
There are many like it, but this one is mine..."
Old Aug 9, 2015 | 10:11 AM
cdoering's Avatar
Brian
That water pump overheats the car and I only have 100 miles on the water pump, Was this rebuilt or just a core?
Chris
StickW31
Apr 14, 2015 07:53 AM
rktolds
Feb 25, 2015 02:01 PM
StickW31
Jan 5, 2014 03:19 PM
StickW31
Dec 7, 2013 04:36 PM
brandon reynolds
Mar 28, 2012 03:16 AM
