70 W30 Distributor Vacuum Advance - needed
Old Dec 8, 2013 | 12:13 PM
70W30Jim's Avatar
Hello,
Your assistance is needed as I am looking for an original Delco distributor vacuum advance unit for my '70 W30 - I believe this is the correct p/n 1973427 or D1315A or MS 427-16. Any information will be greatly appreciated.
949-300-7751 mobile
Old Dec 8, 2013 | 01:04 PM
Octania's Avatar
from the PN database:
1973427
VACUUM ADVANCE unit for pts Dist'r.
...Stamped "MS 427 16" = 16 Crank Degrees advance possible.
__Starts at 10-13" Hg., 4.2-7.3 °Dist @ 16" Hg., 7.2-12.8 °Dist @ 25" Hg.<= per 70 CSM
RockAuto says: AIRTEX / WELLS Part # 4V1190, replaces #1115361, 1973408, 1973427, 88924973, DV1755
w/Dist. No. 1111289, 1111292, 1111469, 1111471.
...Dist'r #'s: 1111981, 1111982, 1111979, 1111977
1969 Olds w/ 455; 69 exc.F-85 w/455;
1970 4400 [442] OAI; 1971 4400 [442] AT exc. OAI;
1972-1973 Marine Engine.
+++ 72 Olds paper PNM:
69 400 Perf. Eng. Or 442 w/ 455 Eng ('<= only 442 w/ 455 in '69 was the H/O Hurst Olds);
69 455 Eng. exc. F85; 70 4400 O.A.I. = 1970 442 W30;
70 3600, 4200 455 Eng. 2 BC (*4) = 1970 1st type used with dist'r # 1111981
71 4400 exc. O.A.I. w/A.T.; 72-73 Marine Perf. Eng.;
70 CSM: Most 455's use '427 VA unit. one '408, one '430 listed"
Old Dec 8, 2013 | 04:03 PM
billmerbach's Avatar
major noob
Do you need the whole dist
Old Dec 8, 2013 | 04:39 PM
70W30Jim's Avatar
Hello Bill,
Just seeking an OEM vacuum advance for my car, but do you have an 1111979 distributor? If so, I may be interested in purchasing an extra one....
Old Dec 8, 2013 | 04:40 PM
major noob
I don't. But I did get lots of vacuum advance pieces today I can check one sec
Old Dec 8, 2013 | 04:50 PM
major noob
Old Dec 8, 2013 | 04:54 PM
Octania's Avatar
any of them new in the box?
my 1968 would use one stamped
418 16
for PN 1973418 and 16 degrees advance provided
Original Poster- I probably have a used one but I assume you need a pretty and new one. Presumably you tried a google search on the number and feepay searches set up to notify you if one appears?
Old Dec 8, 2013 | 04:55 PM
major noob
I have 2 I thought but none in box so I can't tell
Old Dec 8, 2013 | 04:58 PM
major noob
It appears I only have one but it only says b9 and if you also need it I have two points no weights bit one is a Mallory blue streak used little to none still springy and a nos bravo one let me know
Old Dec 8, 2013 | 05:52 PM
Octania's Avatar
"B-whatever" stamp is generic aftermarket
I had that decoder a while back but not sure I can find it.
Google should find it
try google on 1973511 and 1973427
Old Dec 8, 2013 | 05:57 PM
major noob
OK so I take it you aren't interested
Old Dec 8, 2013 | 06:10 PM
The B9 advance can starts at 7-9"Hg and maxes out at 10.3° at 16-18"Hg.
It is the equivalent of the NAPA VC1605.
It's 10° max is not the same as the 16° max that Octania noted above for the 1973427.
Old Dec 8, 2013 | 06:12 PM
major noob
Ok so this one is more than likely for a SB olds
Old Dec 8, 2013 | 06:19 PM
According to NAPA, it interchanges with a wide variety of Chev. and GMC trucks, a few Chev. cars, and a '66 Poncho 389, but not any Olds.
That doesn't mean that it can't be used in Olds applications, but their engineers didn't think it was a good match for any of them.
Old Dec 8, 2013 | 06:21 PM
major noob
Odd it came in a bunch of olds parts
Old Dec 8, 2013 | 07:01 PM
It would be used on an HEI, where you don't need much vacuum advance.
Old Dec 8, 2013 | 07:02 PM
major noob
Ahhh OK thanks Eric(s)
Old Dec 8, 2013 | 07:13 PM
Sorry, Eric, but the B9 is a points advance.
It won't fit an HEI.
Old Dec 8, 2013 | 07:25 PM
Octania's Avatar
Delco ACDELCO Part # D1394C at $24
is the best I can do today
Rockauto.com
I may have a used one in the pile o' distributors, or on the parts car, but the sheer search adds up to more than $25... for a used part... looks unlikely.
Old Dec 8, 2013 | 08:39 PM
507OLDS's Avatar
I have a real one,which has a curved vacuum pipe. I also have a NORS still in the box,also with the curved,#D1315A.
Old Dec 11, 2013 | 05:30 PM
70W30Jim's Avatar
Please send photo(s) of the D1315A unit you have and your asking price to my Email address....
Old Dec 27, 2013 | 12:33 PM
70W30Jim's Avatar
Hello Everyone,
Located and purchase an OEM unit. Thank you all for your assistance!!!
defiant1
Aug 4, 2014 09:15 PM
Octania
Dec 14, 2013 08:34 AM
teqdave
Dec 7, 2013 06:53 AM
pcard
Feb 11, 2013 05:09 PM
donald8619
Jul 22, 2011 07:07 AM
