67 Vista Cruiser Tailgate Motor needed
Old Apr 1, 2013 | 12:43 PM
willys33's Avatar
I think mine is about ready to lay down so I'm on the hunt for another one. Anybody have one to part with?
Old Apr 1, 2013 | 01:51 PM
lemoldsnut's Avatar
Hollander #7 interchange. almost all GM intermediates 64-70 will fit based on Hollander.
Old Apr 1, 2013 | 03:35 PM
willys33's Avatar
Thanks man, I thought that might be the case but that helps confirm. Ha, those guys are probably out looking for the motors too I appreciate the tip!
Old Apr 1, 2013 | 03:50 PM
Aron Nance's Avatar
For what it's worth, I had a two wire (I think) connector in the Silver Bullet
('68 FlatTop) and couldn't find a correct replacement. Ended up contacting A1 Cardone and sending it to them to be rebuilt. Works GREAT, but rather pricey.................
Old Apr 1, 2013 | 04:02 PM
willys33's Avatar
I contacted Cardone and they said there's about an 80% chance they can rebuild it but it must be sent through one of their dealers. Nothing about how much so, is probably about right. ha ha Thanks for the tip
Old Apr 1, 2013 | 06:04 PM
rocwal's Avatar
for information , what is different between side motos and tailgate motors . I have several working motors both LH-RH .
Dan B
Old Apr 1, 2013 | 06:25 PM
copper128's Avatar
Lt. Buzzkill (ret.)
A google search turned up this post stating that a 80's Suburban rear window motor is a bolt-in replacement. He has the info on the 3 vs 2-prong connector also.
http://www.stevesnovasite.com/forums...ad.php?t=64713
Found the part for $62.77 at GMPartsDirect.com
Old Apr 1, 2013 | 06:30 PM
jensenracing77's Avatar
I can't remember what side but either the left or right window motor is the same thing. I have a motor from the back of a 70 vista but i would have to test it.
Old Apr 2, 2013 | 05:38 AM
willys33's Avatar
Dan B
My understanding is the rear window motors have more torque than door glass motors. I don't know for sure but that does make sense.
Old Apr 2, 2013 | 05:46 AM
willys33's Avatar
Thanks for this info. I'll have to dig into this a bit and see what I can find.
Old Apr 2, 2013 | 05:47 AM
willys33's Avatar
I guess I should pull my old motor out and see if I can find any useful info about it. I'll keep you in mind if it looks like yours might work. Thanks.
2blu442
Sep 29, 2017 08:40 AM
danlonchar
Aug 31, 2017 08:18 AM
197064buickspec
Sep 9, 2013 08:55 PM
vistacruiser1971
Aug 6, 2012 05:10 PM
junkman454
May 20, 2011 05:47 PM
