Need wheels for 1966 Delta 88, 14x6, 5x5!
Are you sure about the bolt circle. Might it be 4.75? While doing research for original rims I ran across a set of 65 88 wheels. It appears the original rims might be 14x6 JK drum brake rims with a 4.75 Backspace or 1.25 offset. Not sure on this info. I believe the code was S, Are you looking for original, original style; but not necessarily the original offset, just ones that will fit?
While doing research for original rims I ran across a set of 65 88, It appears the original rims might be 14x6 JK drum brake rims with a 4.75 Backspace or 1.25 offset. Not sure on this info. I believe the code was S, Are you looking for original, original style; but not necessarily the original offset, just ones that will fit?
4.74/1.25 doesn't feel wrong at all, and if your set is from an 65 88 w. drum brakes - then these should be the right ones
PS: I've heared 3,25" backspace before but that was a bit of a guess...
So "Code S" it is.
And yes, I am sure I have 5x5 pattern, since I bought a set of 5x4.75 wheels, restored them and couldn't put them on afterwards!
As Wmachine mentioned, be careful...you DON'T want to buy a set of rims off a 64-66 Jetstar 88 (they used 4.75 bolt circle). Also, I seem to recall some 330 equipped '67 Delmont 88s may have used the smaller bolt circle as well (not 100% sure on that).
The other similarity between J88 & Delmont 330/350 is that they both used the intermediate car's (8.2 B/P or 8.5" O) differential, although the Delmonts had the 5x5 pattern on the axles.
curtis mayfield
Apr 2, 2013 11:39 AM
doc
Sep 23, 2012 09:42 AM
