Need wheels for 1966 Delta 88, 14x6, 5x5!
Old Apr 8, 2013 | 12:16 AM
delta88_frankfurt's Avatar
Hi everybody,
to restore my 1966 Delta 88 back to original, I am looking for a set of stock wheels in good condition.
Old Apr 8, 2013 | 07:00 AM
rktolds's Avatar
Give F85 a shout on here. Josh has some sets. I was going to get a set for my 66 Starfire but I'm running 15's instead.
Old Apr 8, 2013 | 07:03 AM
Thanks! I'll do!
Old Apr 8, 2013 | 07:19 AM
jim larson's Avatar
Originally Posted by delta88_frankfurt
Hi everybody,
Are you sure about the bolt circle. Might it be 4.75? While doing research for original rims I ran across a set of 65 88 wheels. It appears the original rims might be 14x6 JK drum brake rims with a 4.75 Backspace or 1.25 offset. Not sure on this info. I believe the code was S, Are you looking for original, original style; but not necessarily the original offset, just ones that will fit?
Old Apr 8, 2013 | 07:32 AM
wmachine's Avatar
Trying to remember member
88 except Jetstar 88s. S code 14 x 6 5x5 wheels were the standard 14" wheel for the big cars (except J88) for at least '65-'67. I have not tied in the backspace or offset specs for them.
Old Apr 8, 2013 | 07:36 AM
While doing research for original rims I ran across a set of 65 88, It appears the original rims might be 14x6 JK drum brake rims with a 4.75 Backspace or 1.25 offset. Not sure on this info. I believe the code was S, Are you looking for original, original style; but not necessarily the original offset, just ones that will fit?
Original original would be the best, yes. But since I've never heard or read an official offset/backspace spec, a 65 88 set sounds good to me.
4.74/1.25 doesn't feel wrong at all, and if your set is from an 65 88 w. drum brakes - then these should be the right ones
PS: I've heared 3,25" backspace before but that was a bit of a guess...
Old Apr 8, 2013 | 07:44 AM
Unhappy
Thanks a lot. I'm coming closer.
So "Code S" it is.
And yes, I am sure I have 5x5 pattern, since I bought a set of 5x4.75 wheels, restored them and couldn't put them on afterwards!
Old Apr 8, 2013 | 07:47 AM
aliensatemybuick's Avatar
"me somebody" site member
As Wmachine mentioned, be careful...you DON'T want to buy a set of rims off a 64-66 Jetstar 88 (they used 4.75 bolt circle). Also, I seem to recall some 330 equipped '67 Delmont 88s may have used the smaller bolt circle as well (not 100% sure on that).
Old Apr 8, 2013 | 07:54 AM
Originally Posted by aliensatemybuick
As Wmachine mentioned, be careful...you DON'T want to buy a set of rims off a 64-66 Jetstar 88 (they used 4.75 bolt circle). Also, I seem to recall some (or all?) 330 equipped '67 Delmont 88s may have used the smaller bolt circle as well.
...thanks, read above.
Old Apr 8, 2013 | 10:56 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Scott, all Delmonts got the big brakes and 5x5" hubs. The 5x4.75" hub was strictly a J88 thing.
Old Apr 8, 2013 | 11:04 AM
OK then, I shall stop repeating that misconception then!
(I think my confusion was based on the fact that some Delmonts got the Jetaway trans, like the J88s)
Old Apr 10, 2013 | 09:18 PM
copper128's Avatar
Lt. Buzzkill (ret.)
That's true, both Jetaway & TH400 were optional on 330/350 Delmonts.
The other similarity between J88 & Delmont 330/350 is that they both used the intermediate car's (8.2 B/P or 8.5" O) differential, although the Delmonts had the 5x5 pattern on the axles.
Old Apr 11, 2013 | 05:12 AM
AND if it was not confoosing enough, the TH400 was optional on the 1966 J88s, as I recall learning on this site a few years back when such a car, a very nice survivor, was being offered for sale.
octanejunkie
Wheels and Tires
Sep 24, 2014 06:07 AM
curtis mayfield
Apr 2, 2013 11:39 AM
doc
Sep 23, 2012 09:42 AM
2blu442
Nov 20, 2009 07:14 PM
Brad LaGrange
Nov 4, 2009 07:23 AM
