Looking for the tail panel???
Not sure what this is called but mine is full of pin holes and the seam between the trunk pan area and the painted part is about 99% gone. I don't mind welding and fabricating but there's just not that much left to weld to. If anyone can cut me this piece it would be great.
I can be reached through this message syatem or 716-345-3042. A repairable one is all I need.
The areas circled in red is the section I'm looking for.
Thanks,
Mike
Thanks,
Mike
Can't cut anymore until I figure out what’s next. Repairwhat’s there or start to reassemble then replace that last section. I'm notcomfortable cutting this much while on jack stands either but I have some veryexperienced help from my neighbor. You'll hear a lot of "don't lean onthat" every time I look to see what he is doing.
Since the convertible and 4 door share the same deck lid you might find someone with a 4 door parts car that can cut this section out for you.
I may have it but I'm in Oregon and right now work is way to busy for me to get much done with the hobby stuff.
John
John
If you arrange something with 507 Olds, I'm meeting another CO member down in Westfield (Thruway exit 60) this coming Friday morning. Maybe that member could pick up the part from Brian and bring it along since he's coming from Cleveland.
I could get it to you easy enough. I live in Hamburg.
Oldssupreme
Apr 3, 2015 08:36 PM
