Looking for the tail panel???
Old Apr 13, 2013 | 12:35 PM
mmcilroy's Avatar
Not sure what this is called but mine is full of pin holes and the seam between the trunk pan area and the painted part is about 99% gone. I don't mind welding and fabricating but there's just not that much left to weld to. If anyone can cut me this piece it would be great.
I can be reached through this message syatem or 716-345-3042. A repairable one is all I need.
The areas circled in red is the section I'm looking for.
Thanks,
Mike
Old Apr 13, 2013 | 01:29 PM
Octania's Avatar
year and model?
Ambitious project there.
Not sure about replacing the entire body while supported on jack stands.
compared to MI parts, your sheetmetal looks pretty solid to me
Old Apr 13, 2013 | 01:40 PM
mmcilroy's Avatar
Can't cut anymore until I figure out what’s next. Repairwhat’s there or start to reassemble then replace that last section. I'm notcomfortable cutting this much while on jack stands either but I have some veryexperienced help from my neighbor. You'll hear a lot of "don't lean onthat" every time I look to see what he is doing.
Old Apr 13, 2013 | 01:41 PM
mmcilroy's Avatar
Sorry, Forgot to add, 1972 Cutlass Convertible.
Old Apr 13, 2013 | 03:10 PM
2blu442's Avatar
Since the convertible and 4 door share the same deck lid you might find someone with a 4 door parts car that can cut this section out for you.
I may have it but I'm in Oregon and right now work is way to busy for me to get much done with the hobby stuff.
John
Old Apr 13, 2013 | 08:45 PM
507OLDS's Avatar
I have a few of those and you are not that far from me,in NY. I'm in PA.
Old Apr 13, 2013 | 09:24 PM
Rickman48's Avatar
BTW - it's called the rear body panel.
Old Apr 13, 2013 | 09:35 PM
copper128's Avatar
Lt. Buzzkill (ret.)
If you arrange something with 507 Olds, I'm meeting another CO member down in Westfield (Thruway exit 60) this coming Friday morning. Maybe that member could pick up the part from Brian and bring it along since he's coming from Cleveland.
I could get it to you easy enough. I live in Hamburg.
Old Apr 13, 2013 | 09:37 PM
507OLDS's Avatar
I'm in Erie,PA.
Old Apr 13, 2013 | 09:40 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Hey Brian, it's Glenn. I don't know whether you know me on this board, but I'm omegaman78 on ROP.
Old Apr 13, 2013 | 09:44 PM
507OLDS's Avatar
Yes,I thought you meant I was coming from Cleveland,when I am much closer.
Old Apr 13, 2013 | 09:46 PM
copper128's Avatar
Lt. Buzzkill (ret.)
No, I'm delivering some wheels to bryndalfly, he's from Mentor, near Cleveland but he's gotta run right past Erie on the way.
Old Apr 14, 2013 | 07:13 AM
Run to Rund's Avatar
I don't know how rigid the body is--removing the rear panel may make it sag. I'd fabricate a brace to go from side to side a bit in front of the tail panel area.
Old Apr 14, 2013 | 07:54 AM
66400's Avatar
Parts book listing shows the convert shares the same part with the cutlass supreme 2 door. Both of them use the die cast quarter extension caps.
Henry
Old Apr 14, 2013 | 12:58 PM
mmcilroy's Avatar
Thanks 66400, that's encouraging.
Old Jun 11, 2013 | 07:32 PM
MR D's Avatar
2blu442
are you selling the 64 cutlass or looking for parts I have most of the glass and insterment panel
I am in va
2blu442
Jan 10, 2016 12:10 PM
carnell71075
Apr 12, 2015 04:09 PM
Oldssupreme
Apr 3, 2015 08:36 PM
JATA
Jul 10, 2013 06:46 AM
German442
Jul 10, 2009 05:21 AM
