Needing Pistons
Old May 13, 2015 | 12:08 PM
Olds1971's Avatar
Needing Pistons
I need a #6 piston from a 1972 Olds cutlass 350. Not sure on dish size but there stocl for what ever came in 1972 olds 350 with 7a heads
Old May 14, 2015 | 04:21 AM
ROCKETMAN269V's Avatar
Question Needing Piston(s)
Just to be clear; you're looking for one, stock, cast, standard bore piston for a '72 350 engine, correct? The position of the piston (#6) in the engine doesn't matter. What does matter is the size code, A, B, C, or D, that would be stamped on the head gasket surface of the block adjacent to the cylinder bore. I should have what you're looking for. I would be curious as to what caused the issue with the piston. Thanks, Bob.
Old May 15, 2015 | 07:52 PM
Olds1971's Avatar
Ill have to look to see what your talking about. Yes stock for 72 350. 23cc. And the number 6 piston fell and the skirt broke
Old May 16, 2015 | 08:34 AM
piston
Brand new- $20.00; hard to beat that price.
http://www.summitracing.com/parts/sl...ake/oldsmobile
Old May 16, 2015 | 12:05 PM
Compression Distance (in): 1.596 in.
That's a bit shorter than the factory ones at 1.615" and will result in ~.25 lower compression ratio in that one cylinder.
marcusa
Intrigue
15
Jul 23, 2011 07:43 PM
mellowyellow87
Feb 19, 2010 04:29 PM
mo381
Drivetrain/Differentials
Oct 18, 2009 06:37 PM
hotrodj54
Jul 30, 2009 11:23 AM
Cranbrook
Aug 27, 2008 04:27 AM
