Intake manifold hose barb
Old Apr 3, 2011 | 08:31 PM
Summerof84's Avatar
I need several non air factory hose barbs for 350-455 engines. If the car had air, it would use a 155104 heater control valve. Does anyone one have good used, or at least a part number for the non air barb, either GM or aftermarket? I want to clean up my engine compartments.
If I get desperate, I suppose I could thread a new barb onto the 155104 I broke the top off. Has anyone done this with success?
Thanks!
Old Apr 3, 2011 | 08:45 PM
2blu442's Avatar
Sorry, I'm not visualizing the parts you need. Can you post a picture or give more details on where these are located on the intake? John
Old Apr 4, 2011 | 04:39 AM
defiant1's Avatar
Thanks!
Try this thread, Joe Pad had a good idea where to look:
https://classicoldsmobile.com/forums...tml#post268387
d1
Old Apr 4, 2011 | 02:06 PM
Summerof84's Avatar
Well, Joe has the answer as usual!
Not positive the threads are 100% correct as these are listed as Buick 3.8.
http://www.dormanproducts.com/p-43971-500-0481.aspx
The big "CHINA" on them is not too exciting either...
$10 for a box of 3 at O'Reilly's if they actually stock them.
I would still prefer the Olds OEM new or used, and yes I will pay more than $3.50 each for decent ones.
Old Apr 4, 2011 | 02:56 PM
Bluevista's Avatar
Registered
It says they're made of "Material:Metal"?
Chinalloy or Chinesium?
Old Apr 4, 2011 | 04:23 PM
BlackGold's Avatar
Be aware that the original nipple had a restriction in it to limit the pressure seen by the heater core. If you don't have the restriction, you can expect to blow your heater core sooner or later.
Old Apr 4, 2011 | 05:40 PM
oldsconv's Avatar
Inline tube sells repros with the restriction inside.
Old Apr 6, 2011 | 08:43 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I thought the same thing. But decided to be stubborn and proved wrong.
Just for some field data, I put a regular old barb without any restriction in my motor about 4 years ago, and so far so good. Heater core is still the original from 85'. The regular ol' barbs in the help section that I've seen, didn't have the restriction.
Sampson
Mar 24, 2015 09:33 AM
shamusj
Dec 18, 2014 09:28 AM
rptw32
Dec 25, 2011 07:55 AM
svnt442
Jul 17, 2011 04:43 PM
Joeypete
Jul 20, 2009 11:01 PM
