Winshield switch
Old Apr 29, 2011 | 01:04 PM
Axeni's Avatar
Winshield switch
Hey guys I was possibly looking for a windshield wiper switch. Mine the **** pulls off.
________
FriskyRose
Old Apr 29, 2011 | 08:39 PM
507OLDS's Avatar
There is a real small set screw on the side of the ****.I think if you tighten that,you will be fine.
Old Apr 29, 2011 | 08:45 PM
Brian is right, there is a small hex screw. If you've lost it you might be able to get one if you go to a nut and bolt supply. BTW its the same set screw as the ones on the heater/AC *****
Old Apr 30, 2011 | 05:20 AM
69442C's Avatar
Not all wiper switches for 69 Cutlass/442's have this set screw. And this may apply to the 68's too. I'm restoring a 69 442 that has an original switch that uses an internal metal spring shaped like a hexagon that fits up into the back of the **** and provides an interference fit to hold the **** to the switch. I looked for the set screw for several minutes and couldn't find it and eventually decided to try pulling on the **** to see if it came off. So if there is not set screw, you have the other style. No telling how many were made this way. I also have another switch from a 69 Cutlass parts car and it has the set screw. The external appearance of both ***** is identical except for the set screw. And I believe the shape of the stem of the switch itself is different between the 2 styles.
Old Apr 30, 2011 | 06:34 AM
Lady72nRob71's Avatar
JB Weld?
Old Apr 30, 2011 | 07:44 AM
Axeni's Avatar
Thanks much all. Greatly appreciate the information!!
Man I love these forums
________
Washington medical marijuana dispensaries
firefighter5174
Jun 2, 2015 07:48 PM
smf
Mar 28, 2014 09:45 AM
willj
Jan 23, 2013 06:40 PM
1973olds98
Sep 3, 2010 11:25 PM
Fletch
Dec 16, 2009 04:30 PM
