455 engine bolts and oil filter housing for 72 cutlass
Need to find these new if possible.
Know any vendors?
two bolts that hold the oil baffle in. ( under turkey tray and just above the cam.)
72 455 oil filter housing for cutlass (not toro)
oil gallery plugs/ bolts ( they have the small holes to supply oil to cam etc.)
oil pump bolts.
Know any vendors?
oil pump bolts.
[QUOTE=Gary M;1062517]......two bolts that hold the oil baffle in. ( under turkey tray and just above the cam.)......
Be VERY careful in your choice of bolts in this area. If you use bolts that are too long, you can contact the outside of the cam bearings, which can distort them
These are two different sizes; only one has an oil metering orifice, which lubricates the timing chain. The other is merely a plug. The rear metering plug is to lubricate the distributor gear.
I have all of these in oem.
Thanks, Bob.
. oil gallery plugs/ bolts ( they have the small holes to supply oil to cam etc.)
Thanks, Bob.
oldspackrat
Mar 21, 2016 05:17 PM
stanzaschance
Jul 28, 2015 06:38 AM
