Looking for Quadrajet for 1969 350
Old Nov 30, 2011 | 08:45 PM
sykosoft's Avatar
I'm looking for a working condition (not necessarily rebuilt, but ready to go on my intake manifold) Quadrajet for my 1969 350. Ideally, I'd like something from 69-73, but I'm not necessarily picky. Even better would be if it had the linkages for a 2004r transmission, as I have one of those ready to install, but don't have the carb for it yet.
So, to summarize, I'm looking for a working condition 69-73 quadrajet for my 1969 350, preferably with the correct linkages for the 200-4R transmission.
Michael
Old Nov 30, 2011 | 09:42 PM
Rickman48's Avatar
If your motor is stock, you want 69-70 ONLY!
You've a higher compression and a more aggressive curve in the distributer, and need the correct jetting and fuel curve from idle to max rpm.
71 up was lower compression, leaner burn, and GM was trying to do something with pollution - would roast your motor!!
You should be able to make that linkage work on the stock carb, too, as there's extra holes.
Old Nov 30, 2011 | 09:49 PM
sykosoft's Avatar
I'm actually running stock with a 2bbl now, so it's a lower compression engine. I have a 4bbl manifold to put on. Does the same apply?
Old Nov 30, 2011 | 10:08 PM
Rickman48's Avatar
Yes - it's still higher, but not by much.
Old Dec 1, 2011 | 03:02 AM
Yeah, for the least re-tweaking, I'd recommend going with a '66-'70 carb, but others will work, too, and may work fine, depending on how picky you are.
Old Dec 1, 2011 | 10:27 PM
sykosoft's Avatar
I'm going less for power and more for economy. Power is acceptable to me on the 2bbl I have now.
Old Dec 1, 2011 | 11:39 PM
Rickman48's Avatar
Back in the late 70's, a friend got a used 73 Monte with the 350.
Mileage was poor, and he swapped a Q-jet + manifold.
Was surprised he got 3 MPG more, [smaller primaries] and had some guts when he punched it!
Believe he also re-curved the distributer, too.
Old Dec 2, 2011 | 12:05 AM
sykosoft's Avatar
Yeah, pretty much what I'm hoping for. I am running an HEI right now.
Michael
cutsupreme72
Mar 20, 2019 11:12 AM
yankees
Mar 31, 2013 12:51 PM
costpenn
Feb 3, 2012 12:37 PM
auto_editor
Dec 20, 2010 11:24 PM
sanemb
May 28, 2008 05:43 PM
