1968 Cutlass Supreme(4dr) Power Windows Relay
Looking for a working power window relay for a 68 Cutlass Supreme. My left side front and rear open fine, the right side does not move at all but I sometimes can get the front to very slowly roll down and up but then it dies out and I have to assist/force it back closed. Been that way since I got the car. Lets try changing that relay.
Sounds like you need to check the motors/guides/tracks on the right side.
Most likely, they were never greased and the old grease has dried out.
Can you hot wire/directly wire the motor on the right side door to see if it works?
I have a bunch of relays...they hardly ever go bad....let me know what you find out.
Hey guys thanks for posting here. I actually made a thread about this in the electric section with photos if you guys want to chime in that would be great. Theres more info on the issue there.
https://classicoldsmobile.com/forums...tml#post483641
