Power windows and Conv top...no power
Old Apr 10, 2011 | 06:48 AM
squirell's Avatar
Govt slave
Hi Guys,
Recently I was having trouble with my Conv top on my 67 Cutlass.
It would stop 2 or 3 times while going up or down.
I thought it was just the switch,as I would hit the switch again and get it up or down.
Then 2 days later I get in the car and the power windows don't work and the top is dead (I hear a click by the top switch when I press it).
I checked power to and from the fuse for the windows and it OK.
Is there a curcit breaker that controls top and windows ?
Where else can I look.
Old Apr 10, 2011 | 07:11 AM
tpawlik's Avatar
On my 62 Starfire there is a relay behind the drivers side kick panel. Hopefully, someone can share a wiring diagram for your 65.
Old Apr 10, 2011 | 07:34 AM
Bluevista's Avatar
Registered
There should be a circuit breaker for the top and windows on the driver's side of the firewall.
The power from that goes to the relay for the power windows, power for the top should always be hot and should go straight to the switch, usually those work with the key off, if not there may be some sort of relay deal but normally there isn't for the top.
Weird that something is clicking like a relay though?
The fuse in the car is for the power wire to energize the relay when the ignition is on or in the accessory position for the power windows, cruise or power antenna, it doesn't power the windows.
If the top and windows aren't working now that probably has something to do with it, may have been getting ready to go and finally gave out, could be a loose connection too.
The circuit breaker gets it's power from the junction block.
Old Apr 10, 2011 | 08:16 AM
squirell's Avatar
Govt slave
Engine side or interior side of the firewall ?
Old Apr 10, 2011 | 11:14 AM
My vague recollection from my '68 is inside.
Old Apr 10, 2011 | 11:18 AM
Bluevista's Avatar
Registered
Oops.
Engine side, shows it by the accessory grommet in the assembly manual..
Old Apr 10, 2011 | 07:03 PM
squirell's Avatar
Govt slave
Originally Posted by Bluevista
Oops.
Thanks..I'll look for it after work
Old Apr 13, 2011 | 12:21 PM
squirell's Avatar
Govt slave
OK,
Found the curcit breaker..thanks for the help locating it.
Jumped it out and got the windows down.
Now ..where do I get one ?
Old Apr 13, 2011 | 02:27 PM
Bluevista's Avatar
Registered
Rock Auto has them for 15 bucks.
http://www.rockauto.com/
They used them in a ton of cars, your local parts store may have one.
My local NAPA usually has that kind of stuff in stock or can get within a day or less.
Old Apr 13, 2011 | 02:29 PM
hippy72's Avatar
power windows
Hi, my windows on my 67 startes doing the same thing were is the relay (breaker) at? Thanks ken Is it by the wiper motor on the firewall ?
Old Apr 13, 2011 | 03:57 PM
tpawlik's Avatar
That little thing on the firewall is a circuit breaker. The relay is behind the kick panel next to the emergency brake.
Old Apr 13, 2011 | 04:04 PM
tpawlik's Avatar
I could not find a relay to match the original. I bought one online for $7.00You can probably get one at Radio shack. Just match the amp rating. I think I bought 25 Amp relay.
Old Apr 13, 2011 | 05:22 PM
hippy72's Avatar
Thanks !
Xlhowie
Jul 6, 2015 11:58 AM
Xlhowie
Jun 27, 2015 01:20 PM
66olds98conv
Ninety-Eight
Mar 21, 2013 12:52 PM
The_German
Aug 28, 2011 08:18 AM
rustycarr
Mar 7, 2007 06:24 AM
