Choke heater tube
Old Dec 7, 2012 | 11:16 AM
ScottM47448's Avatar
Choke heater tube
Looking for a choke heater tube for a 71 Cutlass S, 350, 4 barrel. OE Intake to OE carb.
Old Dec 7, 2012 | 11:52 AM
stevengerard's Avatar
someone should have them - if not inline sells them
Old Dec 7, 2012 | 12:16 PM
jensenracing77's Avatar
i should have one. send me your address in a PM and i will mail you one. I am in Brazil Indiana. I raced 4 wheelers at your fair grounds before.
Old Dec 8, 2012 | 04:23 PM
It turns out that someone else will have to help him. the only one i have is 455.
Old Dec 10, 2012 | 07:44 AM
jpc647's Avatar
jensen,
do you have the bracket the heat riser tube sit in, the one bolted to the manifold. I tried to pm you but it's not working. :/
Old Dec 10, 2012 | 08:44 AM
there are several styles and big block and small block. I should be able to get PM now again. let me know what you are looking for.
Old Dec 10, 2012 | 10:32 AM
brown7373's Avatar
The part that bolts to the intake has a tube "loop" under it, that completes the whole tube assembly. That is the loop that heats up and makes the choke worki. Fusick has the upper pair and sells the lower that attaches to the manifold separately.
240 Gordy
Oct 11, 2020 10:04 AM
dingusboy
Mar 8, 2014 07:09 AM
junkyard72
Jan 6, 2014 07:05 PM
ROCKET VAPOR
Feb 8, 2013 03:21 PM
cwi inspector
Aug 15, 2012 04:44 PM
