66 442 Carburetor
Old Aug 30, 2014 | 03:37 AM
4-Speed's Avatar
66 442 Carburetor
Interested in a good 4bbl. carb for 66 442, complete correct core is ok-
Thanks-
Old Sep 1, 2014 | 09:56 AM
lunaboy's Avatar
The Rocket Astronomer
I have the correct number from a 66 toro the only thing you would have to do is switch out the throttle plate to the cutlass type. ( held on by one screw ) or if you want a 1967 carb i have plenty of those. pm me your direct email for pic of carb.
Old Sep 1, 2014 | 08:16 PM
Paladin31's Avatar
66 Carb
Hey 4-Speed, I have a 7026250 carb for sale, here's a teaser pic, can get more if you're interested.
Thanks, Brett
Old Sep 1, 2014 | 09:45 PM
lunaboy's Avatar
7026250 came on toronados too, show the teaser pic of the throttle shaft.
Old Sep 1, 2014 | 10:52 PM
L69's Avatar
L69
U must be a numbers guy. But this is the worst carb ever made. This Is the first year and I believe it was recalled also
I do t have any 66 carbs on my 66 cars. Grab one a little newer.
Just my opinion. Good luck
Old Sep 2, 2014 | 05:31 AM
66400's Avatar
There was a factory "fix" of drilling a hole for a screw to secure the inlet fitting. The better cure was using the TriCarb conversion package.
Henry
Old Sep 2, 2014 | 06:44 AM
lemoldsnut's Avatar
I believe I have a few 66 carbs as well. Not Toronado carbs.
Email direct
Larry
lemoldsnut@aol.com
Old Sep 2, 2014 | 07:29 AM
TripDeuces's Avatar
Having had my 66 Rochester apart about a dozen times I can confirm that that year is a pita!
Old Sep 2, 2014 | 09:27 AM
Octania's Avatar
Change to a 2-bbl.... or three!
Old Sep 2, 2014 | 05:22 PM
Paladin31's Avatar
Carbed
As requested...Do these illustrate what you wanted to verify?
Brett
Old Sep 2, 2014 | 05:23 PM
lunaboy's Avatar
Have seen these 66 carbs with the factory mod metal tags if a fix was done. Rochester sold kits with the mod parts and the metal tag. I also have a 66 service repacement carb which is better carb and for those numbers guys would be a better then getting a 67. There is a nice one on eBay also. Found 2 more 66 toro carbs with the mod tag and one 442 carb pictured below.
Old Sep 2, 2014 | 05:46 PM
Paladin31's Avatar
So lunaboy, are you saying the carb I have is worthless?
Old Sep 3, 2014 | 09:32 AM
lunaboy's Avatar
No- i just want to point out the difference of the 66 carbs.
Old Sep 3, 2014 | 07:37 PM
edzolz's Avatar
Anybody have a pic of the fix? I have two of these also.
Old Sep 5, 2014 | 07:01 PM
lunaboy's Avatar
fromhttp://www.442.com/oldsfaq/ofcrb.htm "The 66 factory service advisories tell tales of this problem, so they knew about it. I don't know if there is a permanent fix, but I thought it best to get the h*ll away from these carbs before they really blew up the car. The reason the plug is there is that the casting has to be drilled and you can't drill around a corner. So they drilled, then plugged the hole." if your '66 carb has a plunger and diaphragm thing under the float instead of a needle and seat, it's the bad kind. I think the kits where toro repair kits, not sure but it may be to replace paper filter with metal one so not to use the rubber fuel line where the steel line should be.
Old Sep 5, 2014 | 07:20 PM
lunaboy's Avatar
Henry
the problem is they sealed the hole with some epoxi type adhesive and sooner or later it would leak fuel on a hot intake.
4-Speed
Jul 7, 2014 03:52 PM
70sx455
Nov 3, 2010 10:52 AM
yeahbuddy
Jun 1, 2010 05:38 AM
captn442
Dec 11, 2009 11:16 AM
captn442
Apr 2, 2009 06:51 PM
