alternator bracket
Old Aug 28, 2014 | 05:41 PM
hilbily's Avatar
alternator bracket
Looking for the alt bracket(s) that mounts up high on the left for a 68 Cutlass with air. Thanks. Gil...
Old Aug 28, 2014 | 06:01 PM
2blu442's Avatar
I believe you want the two piece bracket, one shaped kinda like an "H" that goes over the drivers side valve cover. The other shaped more like a "C" that attaches to the front of the head. Here's a couple photos of it, sorry I don't have an extra set at this time. John
Old Aug 28, 2014 | 06:16 PM
Olds442redberet's Avatar
PM sent
Old Aug 29, 2014 | 07:24 AM
lemoldsnut's Avatar
I am pretty sure I can do these as a back up
Larry
email direct lemoldsnut@aol.com
Old Sep 4, 2014 | 01:09 AM
Adam442's Avatar
Second in line
If anyone has another set I need one also - one for ac car thanks
Old Sep 4, 2014 | 03:22 AM
ROCKETMAN269V's Avatar
Smile Alt. brackets
I have a few sets, if anyone else needs some. E-mail me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Oct 1, 2014 | 07:18 PM
hilbily's Avatar
In picture # 2 which holes are used by the power steering pump?
Old Oct 4, 2014 | 02:54 PM
hilbily's Avatar
Trying to get my 68 Cutlass fired up but having a bitch of a time. Got the correct alternator bracket and trying to figure the power steering out. Which bracket do I need for a big block with air? I was told they were all interchangeable but I'm finding out a big block with air is it's own critter, interchangeable with nothing. I'm not sure if I have the right pump wrong brackets, wrong pump right brackets or what. Anybody got a picture of the left front of a big block so I can figure this out before I spin out and go ballistic. Thanks once again guys.
Old Oct 4, 2014 | 03:34 PM
2blu442's Avatar
They are the same power steering setup. Please see my reply to your other post, once we see what pump/bracket setup you have we can help you get it bolted on.
John
Old Oct 4, 2014 | 03:41 PM
jensenracing77's Avatar
Hope these help. you need a spacer between the lower bracket and the block and also a spacer between the lower timing cover bolt and the front bracket. A/C has no effect on the alternator brackets. These pictures are from a 70 and should be the same as your 68 if you have the original brackets. The small block and big block brackets are the same.
442mark
Sep 30, 2017 01:06 PM
xerxes600rr
Aug 30, 2011 06:43 AM
cisco88
Cars Wanted
Mar 1, 2008 09:47 PM
Natas
Nov 24, 2007 06:07 PM
Natas
Nov 15, 2007 05:42 PM
