Want a motor
Old Sep 19, 2014 | 11:30 PM
johnnyjaws's Avatar
Want a motor
Looking for a 1970 455 4bl motorwith th 400 trans would like it running .as long as its complete sorry I live in newburgh ny 12550. 90 miles away from nyc
Old Sep 20, 2014 | 08:17 AM
cutlassefi's Avatar
Uhhh your location would help?
Old Sep 20, 2014 | 12:22 PM
70cutty's Avatar
Beer Connoisseur
Have you looked in classifieds here on CO??
http://https://classicoldsmobile.com/forums/parts-sale/84429-1970-e-headed-running-motor-josh-howard.html
Old Sep 24, 2014 | 10:03 AM
Octania's Avatar
Found one locally
it's about $1000
with trans I believe
'69 455 2bbl
I have looked at it, thumbs up based on 5m inspection.
Chris
517..44 nine.043 two
Lansing MI 48911
Old Sep 24, 2014 | 02:38 PM
johnnyjaws's Avatar
does the 2 bl carb motors come with smaller valves like in the sbo?
Old Sep 24, 2014 | 03:03 PM
Octania's Avatar
Unlikely that any C heads have large valves exc. 442, Toro, H/O. Std issue, no. Are you looking to do NO work at all to the motor then, just install and run? That might be tough to find in the $1k range. 'Cause, while re-doing heads, fitting the big valves is de rigeur, easy as pi.
here is one in GA
http://www.ebay.com/itm/Oldsmobile-4...76f5c0&vxp=mtr
one near me
http://www.ebay.com/itm/331295382554...%3AMEBIDX%3AIT
and a few more
http://www.ebay.com/itm/Complete-Run...84fdf3&vxp=mtr
http://www.ebay.com/itm/Cobra-1979-1...wer_Motorboats
http://www.ebay.com/itm/Oldsmobile-O...5399b4&vxp=mtr
http://www.ebay.com/itm/Olds-455-reb...4b21f1&vxp=mtr
Old Sep 24, 2014 | 05:09 PM
johnnyjaws's Avatar
no ill rebuild the motor just didn't no about the valves I know sbo but never done a bbo just asking will all years bbo bolt into a 70 cutlass s
Old Sep 24, 2014 | 05:44 PM
Octania's Avatar
Sure, that's how they made 442's
A 442 is just a glorified Cutlass, which is a glorified F-85
By the way, what you really want is the 425.
Old Sep 24, 2014 | 06:20 PM
johnnyjaws's Avatar
o really what year were they made
Old Sep 24, 2014 | 06:44 PM
Octania's Avatar
https://www.google.com/url?sa=t&rct=...76247554,d.eXY
"425[edit]
The 425 cu in (7.0 L) big-block was the first tall-deck "big block," produced from 1965 through 1967. It is arguably the best engine Olds made in the muscle car era, although it never made it into a "muscle car". It used a 4.126 in (104.8 mm) bore and 3.975 in (101.0 mm) stroke. Most 425s were painted red, though the 1966 and 1967 Toronado units were light blue. All 425 engines were fitted with forged steel crankshafts with harmonic balancers."
Old Sep 25, 2014 | 04:28 AM
ROCKETMAN269V's Avatar
425
Chris, I agree with you regarding the performance potential of the 425; however, you may want to mention that the cam/lifter differences of SOME 425s can cause confusion. 39* vs. 45* and 0.921" vs. 0.842" lifter dia.
Old Sep 25, 2014 | 08:37 AM
lemoldsnut's Avatar
I have a 67 425 toronado motor. Yes I am a long way from Hudson Valley but with Fastenal we can ship for about $200. Running 67 425 toronado motor
email direct at lemoldsnut@aol.com
Or call west coast time 8 am to 8 pm 541-815-4363
Larry
Old Sep 25, 2014 | 09:15 AM
Octania's Avatar
Larry
I RECOMMEND THAT damn caps lock
other than the hard to find 0.921" lifters, that is the engine to have.
Old Sep 27, 2014 | 05:14 PM
CRUZN 66's Avatar
Olds Fever
I have a 67 425 that I removed from a 67 98..... The previous owner supposedly had just rebuilt it before he had a garage fire and the car was damage but the drive train was not.... It was a running engine before I pulled it about 2 years ago.... It is complete carb to pan with the flywheel (important to note since the flywheel would be different from the 455).... It is located in the Albany NY area just north of you.... If interested, pm me for any additional details........
Old Oct 2, 2014 | 04:38 AM
jcdynamic88's Avatar
455 boston area
http://boston.craigslist.org/bmw/pts/4694627593.html not mine
Old Oct 20, 2014 | 07:37 PM
johnnyjaws's Avatar
thanks I found one going big block!
BLACKCADDY
Jun 2, 2015 09:38 AM
442b
Oct 24, 2011 07:38 PM
tailfins
Feb 21, 2010 07:13 PM
ctrain22
May 20, 2009 11:02 PM
<Stanishj>
Nov 26, 2004 04:33 PM
