Looking for 394 goodies..intake and exhaust manifolds.
Old Jul 12, 2009 | 10:37 PM
Crazy88's Avatar
Registered Lunatic
Hey, I'm in search of either both or the left side exhaust manifold from a dual exhaust equipped 1963-64 88/98/Starfire with the 394. As well as a 4 bbl intake and possibly carb.
Old Jul 13, 2009 | 05:49 AM
Those dual exhaust manifolds are hard to come by. I've only ever seen one and it wasn't for sale. You might check out Evil-bay. I think they turn up there from time to time. Be prepared to spend a good chunck of change though.
Old Jul 13, 2009 | 10:09 AM
Crazy88's Avatar
Registered Lunatic
Ya, it sounds that way...I put in an inquiry on Junkyard Dog...we'll see how that goes... Does anyone have a picture of the manifold, so I know what I'm looking for?
Old Jul 14, 2009 | 02:38 AM
toymaker199's Avatar
From: I live in a small town between D.C. and Philly
Offenhauser had an intake for the 394 that is a dual carb set up i been lookin at it and a set of 380 cfm carbs for it. Go to ofenhausers web site and there is a pic of it.
Old Jul 14, 2009 | 02:46 AM
There is a company called Pypes that has stainless exhaust pipes that will work with some fab work the driverside pipe fits the 2 1/4 driverside and expande to 2 1/2 a few inches after the flange I'm ordering them this week to fit up to my 64 Olds 98. When installing aftermarket exhaust there is no tru bolt on for any car there is always some fab work involved.
Old Jul 14, 2009 | 04:12 PM
Crazy88's Avatar
Registered Lunatic
I just found a 4 bbl intake on ebay listed for a '57 371. It looks nearly identicle to my 2 bbl manifold... says the part # is 569138. Can anyone verify that #? I guess the ports are smaller on the 371? But does it still bolt on?
Here's the listing- http://cgi.ebay.com/ebaymotors/57-OL...4506.m20.l1116
Old Jul 14, 2009 | 04:57 PM
that intake wont fit the 59 to 64 Olds 394 there is a really good tech reference on here that explains the years that the 371 and 394 have interchangability.
Old Jul 14, 2009 | 05:47 PM
Crazy88's Avatar
Registered Lunatic
Cool thank you.
Old Jul 15, 2009 | 08:53 PM
Vintage aftermarket auto parts
Hey I found this place and they stock vintage aftermarket auto parts.
http://www.egge.com
Old Jul 15, 2009 | 09:53 PM
Crazy88's Avatar
Registered Lunatic
That, sir, is very good. Thank you.
Old May 16, 2010 | 04:07 PM
Crazy88's Avatar
Registered Lunatic
394 dual manifolds
I found this for sale... Says dual exhaust manifolds. Looks like 2 driver side manifolds to me. Is this guy trying to pull something? And can the manifolds be swapped side to side and work for duals anyway?
http://i31.photobucket.com/albums/c3...4manifolds.jpg
Old May 16, 2010 | 08:40 PM
chequenman's Avatar
They're both the same manifolds for the left side of a '61 '62, 394 Olds. The left manifold you are looking for is hard to find '63 '64, only and I have a friend with several but he, I don't think will part with any of them as he's building several '63 "98" Conv. right now. I know one of them is NOS, and I've got a really nice used one and I've turned down an offer of $250.00. Good luck on your search but maybe you'll have to make a dual exhaust system with your single exhaust manifold, using the original Left side Manifold from your Single Exhaust system. The '61 and '62 Duals were made using the same single Exhaust Manifolds so it still can be done on a '63 if you need to.
Old May 17, 2010 | 11:35 AM
Crazy88's Avatar
Registered Lunatic
Ok that's what I thought. I was wondering why nobody was really biting on them. Thanks for the info. Can I still use one of these to replace the funky crossover manifold?
Old May 17, 2010 | 12:19 PM
davbell22602's Avatar
Get in touch with Filbily he might have something. https://classicoldsmobile.com/forums...eded-asap.html
Old May 17, 2010 | 01:14 PM
jensenracing77's Avatar
i have a 4bbl intake and carb from a 62 starfire 394. the carb is a core and needs rebuilt. i think the throttle shafts are froze but i can't remember. shipping will be high from Indiana but if interested give me a PM.
Old May 17, 2010 | 01:58 PM
Crazy88's Avatar
Registered Lunatic
I already snagged me a 4bbl intake out of a junkyard if you can believe that. Off of a '60 though. Should fit, correct? I know the exhaust ports are different, but are the intake?
Old May 18, 2010 | 08:33 PM
chequenman's Avatar
Exclamation
I hope you realize the difference between '61,'62, 394 engines as to '63,'64 394, as '63,'64 engines have all aluminum water pump assemblies and the others including '60s are cast Iron, if it makes any difference at all.
Just check it out as you might need Linkage specific to '63.
Old May 18, 2010 | 10:21 PM
Crazy88's Avatar
Registered Lunatic
I'm not sure how the water pump matters in reference to the intake manifold. I just want to know if the '60 manifold will bolt on a '63 motor/heads.
Old May 19, 2010 | 11:46 AM
rougebeats's Avatar
Registered Grease Monkey
I've got the LH exhaust manifold (for true dual exhaust) if your still interested? I'd like to get $225 for it, and you cover the shipping.
I also might have linkage for the 4bbl carb you can have free, just cover the shipping.
I converted my 394 in my Dynamic 88 Convertible over from 2bbl to a 4 bbl and the only issues I really had were linkage issues which were fixed right up with some tinkering and patience. Do be cautious of the trans linkage though, cuz your trans will shift funky. Hydramatics are very tempermental lol
Old May 19, 2010 | 12:01 PM
rougebeats's Avatar
Heres some pics of the exhaust manifold you are looking for-
*NOTE- one of the flange bolts will need to be drilled out and tapped*
Old May 19, 2010 | 02:37 PM
Oldskeeper's Avatar
Thats a nice looking manifold and will clean up and can be drilled out for a new bolt,225.00 is a fair price and if you want dual exhaust for your 394 its the easiest way to go.
Steve
Old Sep 25, 2010 | 10:14 AM
lunaboy's Avatar
The Rocket Astronomer
dual exhust manifold available on ebay
Just got this one if anyone still need one . very nice . will sell to board member for 250.00 buy it now or bid on it here.
http://cgi.ebay.com/ebaymotors/ws/eB...m=330477101565
Old Oct 26, 2012 | 10:07 PM
Rich's63's Avatar
need a 4 bbl intake for a 63 dynamic 88 -394
im interested in the intake manifold if its still available willing to pay the shipping please get back soon thank you...
Old Nov 1, 2012 | 08:37 PM
67 Cutlass Freak's Avatar
Intake
Rich I have 2 - 4BBL intakes, one from a '62 starfire, 1 from a '64 Dynamic 88. Both were beed blasted and painted cast grey. I also have a carb that was rebuilt a few years back and only saw demo derby use. It was drained and should be good to run. If you are serious, I have a friend with a running engine stand that could test run the carb. I can send photos- let me know, Dave
Old Apr 6, 2019 | 10:23 AM
willywonkadude's Avatar
1963-64 394 LH exhaust manifold #587793LH
Anyone know where I can find this driver side exhaust manifold to convert my 394 to duals?
Old Apr 8, 2019 | 07:24 PM
Lazlobassett's Avatar
394 intake
I have a 3x2. Matt 609-346-4669
Old Apr 9, 2019 | 06:55 AM
chequenman's Avatar
Is this Manifold an Offenhauser? or a Oldsmobile cast Iron Manifold? If if is an Offenhauser what Model is it?
willywonkadude
23
Nov 6, 2024 05:17 PM
DynamicIdiot
Aug 10, 2016 08:06 AM
Jandk
Mar 12, 2015 06:45 AM
electra483
Dec 9, 2013 04:54 AM
mike1976
Oct 7, 2012 10:24 AM
