400 E block, Flywheel- Crank ?
Looking for an early 400 flywheel good condition, Here's a shot also an early 400 crank, that is drilled for the pilot bearing, I have a decent auto crank, and can have it drilled, but this seems to be a hit or miss proposition, the last one I had drilled the bearing is to tight, I know this should be posted on another post but what is the correct diameter to drill for the pilot bearing and what is the depth
Thanks Take care Dave
ut442
Mar 9, 2012 11:57 AM
