Radiator top plate for '68 442…..
Old Jan 2, 2014 | 07:52 AM
shamusj's Avatar
Thanks for any help- Mike
Old Jan 2, 2014 | 08:24 AM
rktolds's Avatar
3 or 4 core?
Old Jan 2, 2014 | 09:52 AM
Octania's Avatar
There should be a thread here showing the diffs
The HD-cooling one has two rounded arcs formed into the top center.
I probably have a spare std-cooling one.
Old Jan 2, 2014 | 02:10 PM
shamusj's Avatar
I'm flexible. Car came with AC yet is a standard 400, automatic with freeway gears. Top plate was missing when I purchased car- I'm open to 3 or 4 row….as long as it's correct for '68 442 that's as close as I need to get.
The motor will be completely stock and driven easy with a burn out here and there as needed to relieve stress.
Old Jan 2, 2014 | 06:59 PM
Octania's Avatar
It'll take me a while to scout such a part
anyone else got one handy?
Old Jan 3, 2014 | 04:50 AM
allyolds68's Avatar
I've got a standard cooling one for $30 + shipping.
Old Jan 11, 2014 | 09:37 AM
Octania's Avatar
shamusj
you should probably jump on that
I can't even drive out to the remote site for under $20
So, my part would have to be like $50 to make it worth my while
and, with the ice/ snow/ rain/ flooding, it'd take me weeks to get to it now.
allyolds68 is a certified Great Supplier, so no worries there.
Old Jan 11, 2014 | 11:03 AM
allyolds68's Avatar
shamusj
Thanks Chris
shamus is on it. He's waiting on me for a shipping quote
Old Jan 11, 2014 | 11:15 AM
Paladin31's Avatar
Hey Mike could you post a pic of that upper support please? TIA, Brett
Old Jan 11, 2014 | 01:39 PM
lunaboy's Avatar
The Rocket Astronomer
I have a 68 3 core also if anyone else needs one.
Old Jan 11, 2014 | 06:35 PM
allyolds68's Avatar
68 Standard Top Plate
68 Faux Core Top Plate
Old Jan 11, 2014 | 06:54 PM
Octania's Avatar
lower '68 4-row plate looks right to me
Is the center really offset like that? Never noticed.
The top photo, with that squared off protrusion on the top center aft surface- are you sure that is a '68 item?
I guess so:
Found a few of the file photos
Old Jan 11, 2014 | 07:14 PM
allyolds68's Avatar
I guess so:
The top one is the same as the one you have a pic of (your third pic).
The bottom is a "recreation" from a 67 top plate. The saddles are 2 row on it and it's still taking some tweaking to get it to fit my single row aluminum radiator. I haven't gotten it to fit quite right yet. The fan shroud gets pushed too close to my fan when I use it. I've got to either use a slightly smaller fan spacer or shim the fan shroud a little forward. The latter will require slotting the holes in the top plate. I'd prefer not to do that as it will not "appear" to be a real 4 core.
I've pretty much convinced myself that a 68 4 core top plate is just a 66-67 with larger saddles, a cope out of the front passenger side, a couple extra holes in it, and a spot welded hose clamp on the top. The "extra holes" you have with the ??? marks are the revised holes to fit the 68 fan shroud.
Old Jan 11, 2014 | 07:44 PM
Paladin31's Avatar
Thumbs up
Thank you both {Mike & Chris}. Very much appreciated as the WAC site's [excellent] Oldsmobile resource lists the numbers but not pic's of all variants. Brett
Alex72cutty
Apr 21, 2015 10:30 AM
tcarroll
Dec 26, 2012 11:48 AM
Kevin W
Nov 27, 2012 06:06 AM
60193W30
Nov 4, 2012 05:41 PM
Rusty Boltz
Apr 21, 2012 10:57 AM
