Wanted Posi rear end
Old Jan 26, 2014 | 07:06 PM
ElCaminoGRAN/SPORT's Avatar
Wanted posi rear end for a 1977 cutlass with 3.08 or better gears
Old Jan 26, 2014 | 07:09 PM
oldsmobilty's Avatar
Try contacting 507olds
Old Jan 26, 2014 | 08:00 PM
oldsmobiledave's Avatar
better
What makes a gear BETTER?. Better for acceleration or better for cruising?
Or do you mean numerically larger....as in 3.23 or 3.42 or 3.73 etc.
Why not just use your existing housing & axles & swap in the carrier & gear set you desire?
Old Jan 27, 2014 | 06:48 AM
mister-twister's Avatar
Pm sent
Old Jan 27, 2014 | 07:27 PM
507OLDS's Avatar
I have the 3:08 gears and everything else to convert your existing rear,or I could build a complete rear,but then it needs to ship truck freight.
Old Jan 27, 2014 | 09:32 PM
Deffintly looking for more speed I would prefer 3.42. I have a rebuilt 400 and the stock 2.41 make it a boring ride to much gas to get my 4000+lb 77 cutlass up to speed. 507OLDS I would love to take up your offer but were 671 miles apart I would imagine freight would make it not worth it.
Old Jan 27, 2014 | 09:42 PM
Also if someone could correct me if I'm wrong but I've heard or read somewhere that in the 2.41 rearends you can't put a numerically higher gear in them you have to find a rear with that came with a 2.73 or higher numerically gear.if I can do the gear and posi change in the carrier I have that's the route I will go.If not that's why I was looking for maybe a factory or already built rear to just drop in.Whichever route the car will sit till I get this mod done I drive in a lot of traffic and I'm wasting gas trying to get up to speed after every stoplight.
Old Jan 28, 2014 | 07:12 AM
507OLDS's Avatar
Not true. You can put any gear you want into the housing. The carrier is what the ring gear bolts to. You need a carrier for 2:73 & numerically higher gears.
Where are you located?
Old Jan 28, 2014 | 08:03 AM
507OLDS I'm in s.carolina 29611
Old Jan 28, 2014 | 03:48 PM
507OLDS's Avatar
It would be about $175.00 to ship a rear to your area,dock to dock.
Old Jan 29, 2014 | 12:46 PM
Thanks for the info I was put in touch with a local guy if he doesn't work out I will contact you 507OLDS.
nj_cutlass72
Nov 20, 2019 09:11 PM
350TurBRO
Sep 12, 2014 11:52 AM
RALLYE KID
Dec 20, 2013 11:58 PM
1970442w30post
Aug 2, 2011 05:07 PM
69OldsCutlassS
Drivetrain/Differentials
Sep 9, 2009 01:05 PM
