1970 Cutlass Convertible Seat Belts w/shoulder belts
Old January 27th, 2014, 02:08 PM
jcmoretti's Avatar
Subject heading says it all. I'd prefer black but I think I'm gonna be flexible unless someone out there makes repros... haven't figured that out yet.
jcmoretti is offline
Old March 21st, 2017, 10:53 AM
Alacrity's Avatar
I wanna do the same thing on a 71 convertible. 3 points are better than two...
Alacrity is offline
Old March 21st, 2017, 05:21 PM
marxjunk's Avatar
i had a set made..but have moved 3 times and havent been able to find the lengths etc..i just used a few sets i had lying around..and had a guy put on webbing..that was way before anything was repopped..
id ask for some measurements and pics and copy them..
marxjunk is offline
Old March 21st, 2017, 07:45 PM
stevengerard's Avatar
I thought I posted those measurements before but I can't find them. I've done some research on 3 point belts. Specifically on the fact that in these old convertible the mounting point for the shoulder belt is low. Basically the point that a shoulder belt should be mounted is 15 degrees above or below the shoulder of the occupant. In these old convertibles its about 30 degrees below the shoulder, articles I read said that could be dangerous - just an FYI
stevengerard is online now
Old March 28th, 2017, 09:41 AM
oldspackrat's Avatar
I just pulled a set of shoulder belts from a 1970 Cutlass convertible if you need them or any measurements?
oldspackrat is offline
Old March 28th, 2017, 10:34 AM
Alacrity's Avatar
Hey that's really nice of you. I think I am just gonna help her sell this one as is, at least at first. If it doesn't bring a number she likes, I'll take it and fix it up for me.
Alacrity is offline
Old March 28th, 2017, 01:10 PM
4speed455's Avatar
You have a PM
4speed455 is online now
Old March 28th, 2017, 01:14 PM
Alacrity's Avatar
I do?
Alacrity is offline
Old March 29th, 2017, 06:16 AM
Roger60's Avatar
Shoulder belts
I was told these are shoulder belts. Not positive, but I thought I would share them here just in case.
Roger60 is offline
Old March 29th, 2017, 07:36 AM
those are but from a hardtop - I'm pretty sure the convertible shoulder belts had one hole for mounting but its been so long I can't remember.
Old March 29th, 2017, 01:09 PM
Those buckles don't look like any that I have seen on any 70-72 Cutlass.
Fun71 is online now
Old March 29th, 2017, 01:46 PM
Steven you are correct. The convertibles used a one large bolt & nut mount that mounted to the convertible top frame behind the cylinder cover. They had a plastic sleeve that protected the fabric from wear that slipped between the cylinder cover and the side panel. I just removed a pair of these from a convertible I am junking but did not have time to get pictures of them yet. That style of buckle pictured above was often used in Chevys and Pontiacs.
Old July 11th, 2018, 06:28 AM
PM70's Avatar
Pics?
Stumbled into this thread - I didn't even know shoulder belts were available for a convertible. Can some post pics so I can see how they look and are mounted? I already see where I can purchase them but have no idea how/where they are mounted in the car. It will make my wife very happy. Thanks!
PM70 is offline
Old July 11th, 2018, 07:02 AM
Old July 11th, 2018, 08:34 AM
See post #4, although they do add a sense of safety and I am not an MD, you can let your wife know thee is research out there that says they can do more harm than good. I only put them on occasionally, since they stay in a fix position (unlike modern ones that only have tension when stopping) they can get uncomfortable too.
Old July 11th, 2018, 08:45 AM
71 cutlass convertible
lshlsh2's Avatar
Sounds like a double edged sword . wear them and maybe compress your spine or not and find out how tasty the dash or steering wheel is . i haven't decided if I will add them or not .
lshlsh2 is offline
Old July 11th, 2018, 09:53 AM
PM70's Avatar
Yes, I see your original post now, thanks. Ran into the same thing with my '69 Corvair convertible and decided against all the work involved as well as the safety aspect. I sold the car instead for something a whole lot bigger.
If nothing else, they may save you from being thrown from the car, especially in a rollover, but Im not sure I want to be IN the car during a roll over either.
PM70 is offline
Old July 11th, 2018, 03:07 PM
Yep, I tell people my old convertibles are basically a motorcycle with two extra wheels, you need to be very aware when driving them and I learned the hard way this weekend even when opening a door when parked.
olds 307 and 403
October 10th, 2016 07:07 PM
Custom68
June 13th, 2012 06:58 PM
tmbrennan
August 31st, 2011 03:34 PM
gbas
September 8th, 2010 09:57 AM
stevengerard
September 26th, 2009 08:59 AM
Quick Reply: 1970 Cutlass Convertible Seat Belts w/shoulder belts
