71 442 water pump #407536
Old Oct 27, 2020 | 03:55 PM
sigma76's Avatar
Hi, Looking for 71 water pump #407536 for ac car. Rebuilt preferable, but will consider rebuildable core in good condition. Thanks.
Old Oct 28, 2020 | 06:01 PM
rocketscientis's Avatar
Rebuilt 442 water pump
Believe that I have a rebuilt one for you
oem with cast impeller
#3 Heavy Duty Cooling w/ large 4.8 cast impeller
Housings are crack checked & certified
​​​​​​There are 7 currently available
Omishjon4@gmail.com
Anything else..shroud..fan ??
Images refuse to upload here atm
Not uncommon
Old Oct 30, 2020 | 06:32 PM
Mjnorris's Avatar
I got the 2036 distributor so thanks! How about a water pump for W-30 4 speed, no a/c? Let me know and thanks again. Mark
Old Nov 1, 2020 | 08:24 PM
71-2 455 NOT AIR/COND H20 pump #408328
[QUOTE=Mjnorris;1290227]I got the 2036 distributor so thanks! How about a water pump for W-30 4 speed, no a/c? Let me know and thanks again. Mark
My interpretation is if its W-30 it gets Heavy Duty Cooling , shroud , 6 bladed , clutched fan & 4 core
therefore a #3 HDC pump #407536 , wich due to coarse castings is also # 407586
Going to check flange dimensions on the #1 pumps & will post any variation from 5.1 data suggests
Joe P mentioned discrepancies with water pump data but neglected to be specific
You pump choice should have same dimension as cars current one or you' ll require diffrent punp pully with correct offset
Without A/C , Heavy Duty Cooling , Outside Air Induction ( W-30) , or performance axle 3.90 or better is quick refrence w/#1 on padssengers side above inlet & has 5.1 flange dimension & is castin # 408328 & are 2 nd rarest ones here...I put the oem cast HDC impeller in them to up the gpm flow rate
Pumps with # 3 for quick reference are for 455s with A/C , HDC , W-30s ,and/ or perfornance axle
pump has 6.1 flange dimension , casting # 407586 /536
I myself could use a '2036 distributor if any are available...​​​​
****date 302 is SOLD****
********DATE 302 IS SOLD ********
71-72 Olds 455
#3 pump ..71-72 W-30s with a/c
Heavy Duty Cooling
Air / Conditioning , HDC ,OAI ( W-30 ) , & performance axle applications
Atm 1 of 6 available
all rebuilt pumps housings are crack checked & certified
Omishjon4@gmail.com
#2 is HDC for non Air/Cond , HDC , OAI (W-30) , & performance axle aplications 71-72....5.6 flange dimension , picture has incorrect 5.7 notations
Large 4,8 cast impeller Castin # 408329
Old Nov 4, 2020 | 04:31 AM
sigma76's Avatar
407536 water pump
PM Sent.
Old Nov 4, 2020 | 12:33 PM
RocketDevo's Avatar
The 407586 water pump is the correct pump for all vehicles in 1971-72 with AC.
The 408329 water pump is the correct pump for all 1971-72 W30's
The 408328 water pump is the standard non AC or HD water pump for 1971-72
Old Nov 4, 2020 | 01:01 PM
Good info
thanks
Old Nov 4, 2020 | 03:28 PM
Mjnorris's Avatar
Great info. Is the 8329 good for no a/c 4 speed W30. Please double check the numbers so I can go ahead and buy it! Thanks.
Old Nov 4, 2020 | 04:13 PM
Mjnorris's Avatar
Hey Rocket Man! I’ve checked extensively and 8329 is a go. The $64 question is the cost! Let me know so either pm me or text me at 8583358184. I have a 3.73 rear end. So it’s the one. Thanks. Mark
Old Nov 4, 2020 | 04:18 PM
ROCKETMAN269V's Avatar
Unhappy
Originally Posted by Mjnorris
Hey Rocket Man! .......
Please get the name straight; he's "rocketscientis", spelled incorrectly and all. I'd really appreciate it. Thanks, Bob.
Old Nov 4, 2020 | 06:31 PM
Mjnorris's Avatar
Apologies!! All the best. !!
Old Nov 5, 2020 | 06:47 AM
Thank You! Good Luck! with your search.
Old Nov 5, 2020 | 06:27 PM
Mjnorris's Avatar
Thanks for the good luck wishes! Got it! Thanks!
Old Nov 6, 2020 | 09:16 AM
RocketDevo's Avatar
I see that you already bought, but yes the 408329 water pump is for non AC W30's in 1971-72
Old Nov 6, 2020 | 02:19 PM
My records show the ' 329 & '328 both
Being HDC & #1 NOT BEING HDC for 71-72...having dificulty with man who assumes hes only one with an order & under impression his non - postal money order somehow expidted his order as well as cost me $20 to cash so that trackin # is currently occupying brain cells I could use to remember #1s casting #..& will until any & all negative comments from unnessarary worrying have been retracted & that person WIL understand...or not...
NOT saying anyone's indata is incorrect but certainly want everyones opinion as selling / shipping wrong parts is NOT what were all about here
Two people have exptessed extreme intrest in a #2 & a #3 & until I get caught up on shipping , all other orders will only be accepted with understanding of me being 2 weeks out on shipping or 10 if you think interfereing expidites your order..*.Wil wait n see *
Old Nov 6, 2020 | 03:40 PM
Mjnorris's Avatar
Hey Rocket Devo I’ve been trying for 3 days to get payment info from the one I committed to buy, to no avail, so if you’d with a 2 is good for sale and you get me the price and payment instructions now please do. I can’t buy something I committed to if I get no response.. respectfully.
Old Nov 6, 2020 | 10:47 PM
Almost mentioned that
wasnt certain he was talkin to me...but long as your here whats your understanding of the 71-72 pump applications ?
Old Nov 6, 2020 | 10:57 PM
Mark , if your screwin with the rockets
Please stop...
your killin me
..needed a good laugh...
Believe I finaly emailed you on the 302 dated pump...have 3 diffrent pump deals going on...I think...unless theres more...some days theres to many parts & 1 me.
Old Nov 7, 2020 | 02:05 AM
Mjnorris's Avatar
Was I killin you Smaltz! Block date is 239 heads 212. Would like the pump with the large 2 on it. 408329 is the correct pump. Hope that’s enough to seal the deal. $350 is going out today. All the best. Mark Norris.
Old Nov 8, 2020 | 10:07 AM
Sidestepped & shifted gears on me
joesw31
Sep 15, 2022 09:31 AM
JOHNNYOLDS442
Nov 8, 2020 10:16 AM
MY71W30
Oct 13, 2015 03:40 AM
dc2x4drvr
Dec 12, 2013 06:09 AM
GOSFAST
Oct 1, 2013 06:36 PM
