Frame pads for 350 Olds SB to '64 A-body
Old Nov 17, 2020 | 12:56 AM
LARams1's Avatar
Looking for frame pads/mounts for 350 Olds SB to '64 F85 A-body. Haven't found anything online yet. Any help would be greatly appreciated, thanks. Also the mounts in the pic are they correct, if not what if anyone knows would they fit? Thanks again.
Old Nov 17, 2020 | 04:27 AM
newmexguy's Avatar
You might try the individual in Oregon, and there is another I know of in Austin TX. Would suspect one or both of them have it on the shelf, ready to go.
There is a '66 coupe with 330 engine in one of the El Paso yards. 125 miles round trip from my house. If nothing turns up for you, could acquire, if compensated for time / fuel / and parts. Dave S Dona Ana NM
Old Nov 17, 2020 | 09:23 AM
LARams1's Avatar
Thanks Dave I may take you up on that offer if there's no other ready to go offers and I'd have no problem compensating you for your efforts. Thanks again. 👍
Old Nov 18, 2020 | 06:42 AM
oldspackrat's Avatar
I have some here in Indianapolis. Call me or text me and I will send you pictures. 317-727-7041
Scott
Old Nov 18, 2020 | 08:00 PM
64Rocket's Avatar
when you use the frame pads, they need to be from a 64 to 68 "A" body frame mounts. Also use engine mount #2261. will bolt right in.
Gene
Old Nov 19, 2020 | 01:33 AM
LARams1's Avatar
Newmex & Olds thank you for the offers I've found and I'm having delivered the frame pads from another CO member. This forum is excellent. The replies and help I've gotten I can't say thank you enough 👍💪
Old Nov 19, 2020 | 01:38 AM
LARams1's Avatar
Rocket 🚀 thanks that helps to know the fit will be true first attempt provided I align the pads precisely
Old Nov 19, 2020 | 06:11 AM
Gene
Actually, 64-72 will work. As I noted above, the motor mounts need to match the frame mounts. 69-72 SBO frame pads are dimensionally the same as 64-68 pads for all engines. And even 69-72 BBO frame pads will work just fine with 2328 mounts.
Old Nov 19, 2020 | 07:09 AM
LARams1's Avatar
They're the pads that I posted pics of earlier in the post labeled as '65 Cutlass so still use the #2261 motor mounts?
Old Nov 19, 2020 | 07:11 AM
https://classicoldsmobile.com/forums...on-list-33826/
Old Nov 19, 2020 | 07:13 AM
LARams1's Avatar
Thanks 👍
LARams1
Nov 17, 2020 04:18 PM
MikeManer
Apr 1, 2016 12:00 PM
PatrickF85
Feb 4, 2014 03:33 AM
HOODY
Jan 30, 2011 04:45 PM
Barsteel
Sep 12, 2010 05:35 AM
