1967 Cutlass Need Dashboard
The differences between AC and none are the control unit and the center vent, circled in the first picture. If car has none, there's a blockoff plate.
The second picture shows the indicator used for a Jetaway 2 speed trans. There's a different one for TH400, and others are blocked off. It also shows the default indicator lights with nothing else config.
The third picture shows the indicator lights and clock. Also, the gear indicator is covered.
The last picture shows the Rally Pac gauges.
Do you need a dash pad? What transmission is your car? Do you want a clock? Driver condition or show car? That should help us help you.
