3A heads needed
Old Nov 2, 2014 | 06:46 PM
jones1978's Avatar
3A heads needed
I need at least on 3A head. I have a broke valve cover hole and I am leaking oil. Had a set found a year ago and passed them up. Any help? let me know a price with shipping to 72761.
Old Nov 2, 2014 | 07:26 PM
brownbomber77's Avatar
I'd rather sell ya a set of #3's so you can pick up some compression if you're gonna go that far for just a broken valve cover bolt....
Old Nov 2, 2014 | 07:35 PM
jones1978's Avatar
3's have the 7/16 head bolt right? I have 1/2 head bolts on this motor. I have heard you can have them bored but scared to get the walls too thin. i have a set of #5's, 7'S and #8's if that is the case.
Old Nov 3, 2014 | 01:36 PM
It just takes a drill press and a 17/32 drill bit.
Old Nov 3, 2014 | 01:55 PM
jones1978's Avatar
17/32 drill
Thanks for the info on the drill bit. I may use the #7 I have.
Old Nov 27, 2014 | 07:09 AM
my72olds's Avatar
I've got a #3 and a #6 bothe fresh not sure what's been done to them as they are on a 73 350 with new pistons fresh crank 10/10 I'm not sure how someone could run two diff heads but the guy I bought it from said the motor was running in a delta they pulled it and sent to machine shop ...... What I can see is screw in studs and guides with 1.6 roller tip rockers
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
