Throttle bellcrank rod to carb
Old Oct 19, 2014 | 06:54 AM
Rick67OldsVert's Avatar
Hi,
I need the throttle rod from the bellcrank to the carb for a 67 Cutlass with the 330. Any help would be appreciated! It is a four barrel carb.
Old Oct 19, 2014 | 07:51 AM
Octania's Avatar
https://classicoldsmobile.com/forums...yton-ohio.html
maybe you need this at one end?
http://www.ebay.com/itm/Genuine-GM-S...880c07&vxp=mtr
ck the PN manual for what your car used.
Old Oct 19, 2014 | 10:10 AM
Thanks!!
Old Oct 19, 2014 | 10:46 AM
Those bushings/grommets can be gotten from your local auto parts store for way less than $23. This one is from Jegs:
http://www.ebay.com/itm/Quick-Fuel-1...item5d4fc2c984
Old Oct 20, 2014 | 09:39 AM
Octania's Avatar
Another great alternative for when NOS GM is not required.
I think I have seen the spherical swivel end at the hardware store, so with a tap n die set, rod from an old Chevy, and hardware store swivel, you should be all set.
I do have some rods on hand if you care to buy used.
would need your exact length needed, center to center.
517-449-0 four three 2
Old Oct 20, 2014 | 03:12 PM
Ok thanks. I will make up my mind on the carb I will use and then measure the length.
Old Oct 20, 2014 | 03:14 PM
lemoldsnut's Avatar
I can do the original rod if you need it. email direct
lemoldsnut@aol.com
Larry
defiant1
Feb 4, 2020 08:53 PM
miked
Oct 26, 2013 07:09 PM
widowmaker1201
Dec 2, 2012 01:52 PM
aliensatemybuick
Nov 14, 2011 07:01 PM
DennisG.
May 23, 2008 11:39 AM
