1968 Cutlass LEFT Hood Hinge
Old Dec 1, 2014 | 12:37 PM
Christophe2m6's Avatar
Hi!
Would need a 1968 Cutlass LEFT Hood Hinge!
Hope I'll find what I need here!
Thanks for your help!
Old Dec 2, 2014 | 04:53 AM
ROCKETMAN269V's Avatar
'68?
Is that a typo, as the car in your pic, is a '69; or is this for another vehicle?
Old Dec 2, 2014 | 06:39 AM
Yes, indeed!
My car is a 1969, but with a 1968 front Left fender... and hinge!
Hinge is completely out, so before replacing fender next year for new paint, would need a 1968 Left hinge!
Old Dec 2, 2014 | 07:34 AM
Originally Posted by Christophe2m6
Yes, indeed!
Personally I would use a correct 1969 hinge and modify the fender to match. If you are firm on using a 1968 hinge, be aware that Cutlass and full size cars used the same hinge that year, so one from a 1968 Delta 88 or Ninety Eight will also work.
Old Dec 2, 2014 | 09:26 AM
Thanks Joe for your answer!
That could be a solution!
Would you have some tips/advices to give me to do this modification correctly?
(How to get solid anchors for the hinge?)
Old Dec 27, 2014 | 01:26 PM
Hi!!
Found a 1968 TORONADO left hinge.
Will the hinge work for my car?
Thanks!
Old Dec 27, 2014 | 02:35 PM
starfire's Avatar
If you have a '69 hinge on the right side, having a '68 hinge on the left may be problematic (but then again, it might not be). The '68 hinge does not open up as far as the '69 does, I don't know if that will make the hood more prone to closing without notice as the right side will not be all the way open.
RetroRanger
Nov 11, 2024 09:45 AM
Al Sanchez
Mar 12, 2013 09:09 PM
sammy
Nov 25, 2012 04:14 PM
Nilsson
Aug 21, 2009 03:32 PM
