1955 Oldsmobile 88
Old Jan 16, 2018 | 03:08 PM
Bennyp's Avatar
1955 Oldsmobile 88
Looking for parts for my 1955 Oldsmobile 88 2dr hard top. I need a back window glass, floor pans both left and right side,and front disc brakes conversion kits. If anyone can help even with info thanks.
Old Jan 16, 2018 | 03:15 PM
2blu442's Avatar
Hi Benny, welcome to the site! Where are you located? I've got the rear glass but that would be a challenge to ship. John
Old Jan 16, 2018 | 06:22 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The disk brakes will require the installation of a firewall mounted master cylinder. There are kits available but I am not sure who makes them. I am sure somebody will speak up. The floorpans should be the same for 54 and a Buick might possibly work.
Old Jan 17, 2018 | 05:41 AM
jozw30's Avatar
The back glass is now reproduced. You will have a difficult time finding a really nice used one. And it’s a lot of effort to remove and install........
Old Jan 17, 2018 | 09:33 AM
2blu442's Avatar
I agree with you about the effort! I was surprised how the trim and gasket fit and it was a royal pain removing both front and rear glass. Mine is in good condition, but if new isn't too expensive I'd think that might be a better way to go. Then the glass shop is responsible for safe shipping!
John
Old Jan 17, 2018 | 09:35 AM
WHIPOLDS's Avatar
I have a tinted back glass for a 1956. Not sure if they interchange.
Rick
Old Jan 18, 2018 | 06:04 PM
Bennyp's Avatar
Rick
hi Rick I was told the 56 hard top will fit the 55 but not 100% sure
Old Jan 19, 2018 | 03:18 AM
WHIPOLDS's Avatar
Thanks - Where are you located? If interested I will send you a picture.
Rick
Old Jan 19, 2018 | 04:18 AM
jozw30's Avatar
Post and hardtop are different. Look at Buick as well, glass will interchange.
Old Jan 21, 2018 | 06:42 AM
Bennyp's Avatar
Thank you all for helping
Old Jan 21, 2018 | 08:37 AM
Tedd Thompson's Avatar
Disk brake Mike makes a conversion for your car and it works well. The advantage he offers is that you can order his kit or use used parts off a doner car that he lists and save the difference in cost/ shipping. http://www.discbrakemike.com
As noted above you will have to change out your master cylinder and vacuum tank. because the old system won't support the newer brakes. This is true with any brake conversion you find..... Tedd
Old Jan 24, 2018 | 08:06 PM
black67442's Avatar
interchange.
Rick
1954-1956 two door hardtop back glass are all the same. Same with the sedans/fitting sedans of these years. Thank you.
Old Jan 25, 2018 | 04:16 AM
WHIPOLDS's Avatar
Good to know !
Thanks!
Rick
Old Jan 31, 2018 | 08:49 AM
jcdynamic88's Avatar
https://southcoast.craigslist.org/pt...468819543.html not mine
Old Jan 31, 2018 | 10:51 AM
Bennyp's Avatar
Originally Posted by jcdynamic88
Thank you for the info it was most helpful
Old Jan 31, 2018 | 11:40 AM
53Ragtop's Avatar
I suspect that the 2 Dr parts in the above Craigslist add will NOT fit a 2 Dr Ht. 2 Dr Ht is likely to be unique. I know for sure that is the case for all 57 Olds and Buick’s.
Old Jan 31, 2018 | 12:01 PM
where does the ad say if it's a hardtop or sedan?
Old Jan 31, 2018 | 12:36 PM
53Ragtop's Avatar
It doesn’t, however it does say 2Dr. In my era that meant a 2 Dr Sedan. The OP says he is looking for a 2 Dr Ht glass. Just pointing out that further investigating is required.
Old Jan 31, 2018 | 12:47 PM
in my era 2 dr means NOT a 4 door,at least it's half way there
Old Jan 31, 2018 | 01:42 PM
53Ragtop's Avatar
Sorry I seam to be offending you! I NEVER said anything about a 4 Dr. There were 2 Dr sedans!
Old Jan 31, 2018 | 02:44 PM
there's no problem here,i was just trying to help,hopefully the op can find what he needs.conversations like this remind me why i don't like the internet,seems like frequently statements are misunderstood.
drftsub
Jun 7, 2011 11:50 AM
toyktdlgh
Jun 2, 2008 05:52 AM
toyktdlgh
15
May 14, 2008 06:52 AM
malatu
Apr 27, 2008 04:52 AM
Tedd Thompson
Apr 12, 2008 05:24 PM
