1955 Oldsmobile 88
1955 Oldsmobile 88
Looking for parts for my 1955 Oldsmobile 88 2dr hard top. I need a back window glass, floor pans both left and right side,and front disc brakes conversion kits. If anyone can help even with info thanks.
The disk brakes will require the installation of a firewall mounted master cylinder. There are kits available but I am not sure who makes them. I am sure somebody will speak up. The floorpans should be the same for 54 and a Buick might possibly work.
John
Disk brake Mike makes a conversion for your car and it works well. The advantage he offers is that you can order his kit or use used parts off a doner car that he lists and save the difference in cost/ shipping. http://www.discbrakemike.com
As noted above you will have to change out your master cylinder and vacuum tank. because the old system won't support the newer brakes. This is true with any brake conversion you find..... Tedd
there's no problem here,i was just trying to help,hopefully the op can find what he needs.conversations like this remind me why i don't like the internet,seems like frequently statements are misunderstood.
