62 starfire 394ci
Old Jan 3, 2018 | 06:51 PM
Oldpac62's Avatar
62 starfire 394ci
Wanted driver side exhaust manifold
Old Jan 4, 2018 | 05:51 AM
Oldskeeper's Avatar
Hello Oldpac62,
Are you looking for the original drivers side manifold or are you looking for the 63/64 left hand dual exhaust manifold?
Steve
Old Jan 4, 2018 | 08:31 AM
Oldpac62's Avatar
Exhaust manifold
Originally Posted by Oldskeeper
Hello Oldpac62,
Steve
Steve thank you for your help .it don't have to be original if something else will work OK. The olds is not for show but trying to keep it a nice driver, 394ci completely rebuilt and trying to make it nice
Old Jan 4, 2018 | 08:35 AM
Oldpac62's Avatar
forgot to tell you drivers side and dual exhaust I don't think I will need the heat rizer in fl ?
Old Jan 4, 2018 | 09:41 AM
Oldskeeper's Avatar
The 62 dual exhaust was just a bend in the pipe and a blocker plate on the right hand manifold, your starfire should have the blocker plate on the right. The single and dual used the same manifolds in 62. The left hand manifold of any 62 full size will work, what's wrong with yours? No you shouldn't need the heat riser in Fl.
Old Jan 4, 2018 | 09:57 AM
Oldpac62's Avatar
Exhaust manifold
[QUOTE=Oldskeeper;1066076]The 62 dual exhaust was just a bend in the pipe and a blocker plate on the right hand manifold, your starfire should have the blocker plate on the right. The single and dual used the same manifolds in 62. The left hand manifold of any 62 full size will work, what's wrong with yours? No you shouln't need the heat riser in Fl.[/QUOTE the studs broke off and garage said I should look for a good one
Old Jan 4, 2018 | 11:22 AM
Oldskeeper's Avatar
Post a picture of the numbers on the side and a full side view when you can, I'll see what I have.
Old Jan 6, 2018 | 02:51 PM
Oldskeeper's Avatar
I have this manifold for your 62 starfire off of my starfire. I can't get to it until later when it warms up (-38 with wind chill today).
If interested I'll make a note and dig it out for you. Private massage me with mailing address and I'll figure out shipping costs.
Steve
Old Jan 6, 2018 | 09:56 PM
OLDSter Ralph's Avatar
[/QUOTE the studs broke off and garage said I should look for a good one/QUOTE]
Don't throw the exhaust manifold away, the studs can be removed or carefully drilled out. Sounds like "they" just want to replace parts.
Ralph
Old Feb 19, 2018 | 09:38 AM
Oldskeeper's Avatar
I have found my bin with exhaust manifolds for 62 and 63 394's. Still interested in one I'll set it aside, I need the number to check for the correct one for you.
Steve
Old Feb 19, 2018 | 03:48 PM
Oldpac62's Avatar
[QUOTE=Oldskeeper;1076115]I have found my bin with exhaust manifolds for 62 and 63 394's. Still interested in one I'll set it aside, I need the number to check for the correct one for you.
Steve[/ QU
Steve thank you for all the help but I have it in a machine shop getting repaired. Hoping they can fix it I am sure I will need other parts soon
Old Feb 19, 2018 | 04:16 PM
Oldskeeper's Avatar
That's OK, back in the case it goes until next time.
Kaline
Apr 18, 2022 03:35 PM
gringocordoba
Feb 3, 2011 10:18 AM
gringocordoba
Dec 10, 2010 04:31 PM
sssingo
Nov 12, 2008 09:25 PM
Kaline
Mar 23, 2008 06:53 AM
