1963 394ci breather hose woes??
Old November 11th, 2008, 02:33 PM
sssingo's Avatar
Cn anyone tell me whether I can do without the breathers on each rocker cover and switch them for earlier 1950's rockers with no breathers? I have a breather cap on the oil fill is that enough?
Also do 1950's rocket rocker covers fit my engine? The ones with the plug wire covers?
sssingo is offline
Old November 11th, 2008, 08:47 PM
59-59-59's Avatar
Any Olds valve cover from a 1959 - 1964 371 and 394 will fit. However the '59 and '60 covers have absolutely NO holes in them for the PCV. This is what I did - I have a '62 394 and bought rare Edelbrock valve covers for them which have no holes in them. I didnt want to drill into them and put a breather so I drilled a hole in the valley pan metal cover and adapted a down draft tube to it in the rear of the pan.
59-59-59 is offline
Old November 12th, 2008, 03:04 AM
Junior Member
88 coupe's Avatar
Originally Posted by sssingo
........ I have a breather cap on the oil fill is that enough? ........
Yes it is. It's how the first California retrofits were done.
Norm
88 coupe is offline
Old November 12th, 2008, 11:29 AM
sssingo's Avatar
59-59-59 Don't suppose you've got any pics of your breather setup? Did you use some of the existing breather hose grommets and pipe work.
sssingo is offline
Old November 12th, 2008, 09:25 PM
59-59-59's Avatar
No, I dont have any pics of this set up and forgot to mention the valley pan was an aftermarket finned aluminum one they make brand new. I used a '59 road draft tube set up with minor bending and had to drill ( obviously ) 3 holes in the valley pan ( one for the tube and 2 for the mounting bolts ) and grind a couple fins down for this to work
59-59-59 is offline
Kaline
April 18th, 2022 03:35 PM
5998DownUnder
December 27th, 2013 09:12 PM
gringocordoba
February 3rd, 2011 10:18 AM
gringocordoba
December 10th, 2010 04:31 PM
Kaline
March 23rd, 2008 06:53 AM
Quick Reply: 1963 394ci breather hose woes??
