455 W/Z Manifolds
Old May 15, 2017 | 11:21 AM
oldsguybry's Avatar
NOVICE car nut
455 W/Z Manifolds
I'm in need of a pair of these and now would be the time for me to buy them . Let me know if anyone has a set they want to part with , Thanks Bryan
Old May 15, 2017 | 01:01 PM
ROCKETMAN269V's Avatar
455 W/Z Manifolds
I have a pair. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old May 15, 2017 | 07:21 PM
442crzy's Avatar
PM sent
Old May 15, 2017 | 08:32 PM
marxjunk's Avatar
i have an incredible survivor pair off a 70...you cant buy this patina..
Old May 19, 2017 | 07:28 AM
oldsguybry's Avatar
NOVICE car nut
I was talked into buying from Thornton off of E-Bay , I could of found them cheaper perhaps but these are nice and shiny .
Old May 19, 2017 | 09:44 AM
Thanks for the update.
Old May 21, 2017 | 05:25 AM
oldsguybry's Avatar
NOVICE car nut
The buyer cancelled my order and refunded my money on E-Bay because of lack of stock / damaged parts .
I still need these ....
Old May 21, 2017 | 11:11 AM
W&Z manifolds
Email sent.
Old May 21, 2017 | 11:19 AM
442crzy's Avatar
PM sent to follow up
Old May 22, 2017 | 01:25 PM
442fanatic's Avatar
You can buy direct from Thornton, or through parts place has them.
Old Jun 4, 2017 | 12:03 PM
oldsguybry's Avatar
NOVICE car nut
Got a set , thanks for every ones help .
Old Sep 24, 2017 | 08:08 AM
oldsguybry's Avatar
NOVICE car nut
Now I have to figure out how to get the broken bolts off of the motor where the exhaust manifolds hook up .
Old Sep 24, 2017 | 04:57 PM
marxjunk's Avatar
is there bolts hanging out or broken flush?
Old Sep 24, 2017 | 05:17 PM
oldsguybry's Avatar
NOVICE car nut
They're hanging out .
Old Sep 25, 2017 | 04:27 PM
marxjunk's Avatar
access to a mig welder?
weld a loose fitting nut on it..does 2 things...heat and a way to get a grip...
ive done it many times..they usually just back right out...easy to do
get a nut big enough to slide over the shank...cut the shank off if too long and just weld the hole up, melting the nut to the shank..it'll come right out...
Old Sep 25, 2017 | 05:46 PM
RetroRanger's Avatar
72 Olds CS
I had one stuck used silikroil and vice grips everyday for like 2 weeks eventually was able to work it out...
Old Sep 26, 2017 | 04:57 AM
oldsguybry's Avatar
NOVICE car nut
I don't have access to a welder unfortunately .
I never heard of Silikroil , but I do have PB Blaster. Which one is better ?
I had an idea though ..... If I can't weld a nut on the bolt like marxjunk said , I was possibly going to put two pieces of toothed metal on each side of the bolt and clamp them to the bolt itself so it don't turn . I would have to spray a lubricant ( like mentioned above ) and heat the area it's screwed into , and hopefully it will come out without breaking . Worse case scenario , I can get them drilled and tapped for $25 a bolt at a race shop . Of course I would have to take the heads off which need new gaskets probably anyhow , along with the leaking intake manifold gasket as long as I'm there .
Old Sep 26, 2017 | 11:23 AM
Stefano's Avatar
Let me know the dates and what you want for them.
Old Sep 26, 2017 | 12:40 PM
72 Olds CS
I had an idea though ..... If I can't weld a nut on the bolt like marxjunk said , I was possibly going to put two pieces of toothed metal on each side of the bolt and clamp them to the bolt itself so it don't turn . .
that sounds like vice grips
which is better probably same stuff lol ive used both, its hard to quantify which is better, ive had successes and failure w both.
link to silikroil
Amazon Amazon
I would heat it, spray it w PB (or what you have) hit it w a hammer and vice grip it w out wrecking it, if it doesnt move spray it , and repeat again tomorrow!!!
Old Sep 26, 2017 | 03:48 PM
marxjunk's Avatar
long gone..i posted that in may, they went on a survivor car that needed them
Old Sep 26, 2017 | 06:23 PM
Stefano's Avatar
Ok thanks.
Old Sep 26, 2017 | 10:07 PM
oldsguybry's Avatar
NOVICE car nut
link to silikroil https://www.amazon.com/SiliKroil-Pen.../dp/B0003041WK
I tried vise grips but they spin on the bolt . I have a brand new pipe wrench with some nice sharp teeth I was going to maybe clamp the open end portion of it to get a better grip on the bolt , but I'm more then likely going to have to do like you said and just spray it everyday for like a week , heat it good , and hope the damn bolt don't break on me .
Old Sep 27, 2017 | 09:40 AM
marxjunk's Avatar
heres what i have seen at machine shops for steel and aluminum..works well
they heat the bolt red hot and whack it with a hammer on the end..they make the shank that is showing swell and shocks the threads..the heat and the hammer loosens them and they almost fall out,,,ive never tried it, but i watched a 90 lb 60 year old woman at a machine shop here in town remove 8 bolt in about 15 minutes....pretty impressive..her husband died, and she was running the show..and knew the ropes, thats for sure
ive seen it at other shops too, i just got a front row seat this time...
there was between 1/4 and 3/4s of the bolt sticking out on each, she used a torch, heated them till bright cherry red, took a 2 pound ball peen, hit it til the cherry was dull/grey, put the torch down, grabbed vice grips and they just backed out with little to no effort..impressive to me, but i'm sure just simple science working
the heads where off the motor and on a steel bench
Old Sep 27, 2017 | 09:43 AM
oldsguybry's Avatar
NOVICE car nut
Wow that is awesome !
Limey
Apr 15, 2013 10:45 AM
monzaz
May 15, 2012 01:23 AM
olds4life
Jul 15, 2008 07:34 PM
citcapp
Nov 26, 2007 07:54 AM
