Temperature Sending Unit
Old June 9th, 2017, 01:42 PM
Gary
Gary's 2 442-S's Avatar
I need advise as to where I can find an electrical connector that will fit on this temperature sending gauge? I have called M&H and American Auto Wire and they dont sell individual connectors. Any advise or suggestions would be greatly appreciated. Thanks in advance.
Gary
Gary's 2 442-S is offline
Old June 9th, 2017, 02:20 PM
Well, typing GM single wire coolant temp sender connector into Google is a good place to start.
The aftermarket ones all appear to be incorrect white, unfortunately.
https://www.summitracing.com/parts/pco-5665pt/overview/
http://www.repairconnector.com/produ...Connector.html
joe_padavano is offline
Old June 9th, 2017, 02:48 PM
Gary
Thanks Joe for the help. I will order one and just paint it.
Old June 9th, 2017, 03:40 PM
72455442RA's Avatar
a good place to find em is ....
74-87 ish chevy trucks they almost all have gauges and that style end on the sender and a green wire still ... My 86 1/2 ton 4x4 350 has that as well as my 83 gmc dually
located drivers side head by the exhaust ...
any wrecking yards nearby or craigslist ?
I may have one in my electrical box ... I chop nice ones off when I find em
Scott
72455442RA is offline
Old June 9th, 2017, 03:51 PM
I had moved your post to parts wanted as someone might have a fubar harness with one still attached.
oldcutlass is offline
Old June 9th, 2017, 04:24 PM
Old School Olds
tru-blue 442's Avatar
Gary, I probably have one if you haven't ordered one yet.
tru-blue 442 is offline
Old June 9th, 2017, 05:51 PM
Gary
Thank you for the offer but I ended up improvising and made one from a female 18ga 56 connector
Old June 9th, 2017, 05:53 PM
Gary
Scott
Thanks Scott for your offer but I ended up making one.
Old June 9th, 2017, 06:21 PM
Old School Olds
Looks good.
Old June 9th, 2017, 06:32 PM
Put a little dielectric grease on that connection to avoid corrosion.
Allan R is offline
Old June 9th, 2017, 07:19 PM
That's exactly what I did with a friends Chevelle... I didn't know if you wanted to stay original or not.
Old June 9th, 2017, 07:27 PM
Gary
I did not know what it looked like and after Joe sent that picture I got to thinking since I have 56 connectors I would just try my hand at making one. I am not all that in to being everything original. What I always want is something functions well and looks good. The fun of the hobby business.
Old June 10th, 2017, 03:28 AM
Actually, the correct terminal is the single wire female terminal, with a slot in it. Harvesting from a truck harness is a great idea. Mouser has the correct new ones in stock for 32 cents each.
The Delphi part number is 2962965-B
Old June 10th, 2017, 06:51 AM
Gary
Good source of information Joe. I am ordering a few of them,
Thanks again.
Old June 10th, 2017, 04:42 PM
Majored in rear tire demo
2Olds4U's Avatar
And you may want to rethink the teflon tape on the sending units. Erroneous readings have been reported. The base is brass, it won't seize. Not in your lifetime anyway.
2Olds4U is offline
Old June 11th, 2017, 08:39 AM
rr69ho's Avatar
These are actually the correct senders.
rr69ho is offline
Old June 11th, 2017, 08:47 AM
442fanatic's Avatar
Saw several alternative methods illustrated. I work at a john deere equipment store. We carry that connector in stock, have to have them provide the clip to crimp the wire too.
Otherwise basic electrical pack from a hardware store with a simple female spade connector I saw in a pic above.
442fanatic is offline
TheRuss
January 22nd, 2018 11:42 PM
68RocketAction
December 18th, 2014 11:19 AM
Kace
May 22nd, 2010 06:22 AM
dynamic88
July 12th, 2009 08:15 AM
boese1978
January 22nd, 2008 11:56 AM
Quick Reply: Temperature Sending Unit
