Temperature sending unit
Old May 21, 2010 | 06:58 PM
Kace's Avatar
Greetings. Having a problem. Have a 68 convertible 350 2bbl. with A/C. Motor has the thermostatic vacuum valve in driver side port of intake. I dont see a temp. sensor unit in intake anywhere. There is a plug in port on pass side of intake. I bought one to put in but it is too big for hole. Where does that sucker go? I have a loose plug hanging next to oil sending unit which I'm sure is for temp sensor. Is there a smaller diameter temp sensor for that motor? Not comfortable running motor without it. Appreciate any response.
Old May 22, 2010 | 06:22 AM
Lady72nRob71's Avatar
Sounds like the vac valve is not supposed to be in that port - the temp sensor should be there instead.
The vac valve should be in the other port. Is this vac valve even supposed to be there? Is it original to the engine? A picture might help. If aftermarket, it might not be the right one and they stuck it there cause it did not fit in the other hole.
Just my guess.
TheRuss
Sep 30, 2025 05:33 AM
dynamic88
Jul 12, 2009 08:15 AM
Pfiffle
Feb 21, 2008 06:43 PM
boese1978
Jan 22, 2008 11:56 AM
