PDA
View Full Version : Transmission
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13
  1. Shifter conversion
  2. TH400 new to me
  3. 1964 F85 2 speed to 3 speed swap stall converter question
  4. Transmission hesitation
  5. 1983 Delta 88 transmission leaking
  6. 66 Cutlass Th350 install
  7. 2004R users- TCC lockup?
  8. Vibration after TH400 reinstall – smooth in Neutral, shakes in Drive - 1971 442
  9. 200-4R won’t downshift from 3rd
  10. Automatic to manual swap - pilot bushing or bearing
  11. Shift cable question - TH350 to 200-4R swap
  12. 1967 Oldsmobile 330 transmission recomendations.
  13. TH350 Leak chasing
  14. th200-4r governer advice
  15. tkx in 68 cutlass rear ratio
  16. Is there a replacement OverDrive for Turbo 400?
  17. Muncie case bushing recommendation
  18. T0160 Tail Stock Bushing Removal Tool
  19. 1977 T50 replacement options
  20. Any TKX 5 Speed Users Here?
  21. 200-4R Tail Stock Movement - Worn Bushing?
  22. What Turbo 400 is this ?
  23. 1964 Rotomatic
  24. TH400 noise under load – smooth shifts, no slipping, looking for advice
  25. TH350 2-3 slipping with shavings
  26. TH400 oil pan ?
  27. TH 400 Tag questions
  28. Jetaway VS TH 350
  29. 200-4r not shifting
  30. Looking for TH400 Tailshaft Bushing
  31. clutch linkage
  32. 88 & 98 Jetaway.
  33. Muncie 4 speed fluid check
  34. 70-72 Cutlass auto floor shifter wood knob alternatives?
  35. TH350 & missing piston return springs
  36. 2004r What tools do I need?
  37. Checking the fluid
  38. TH400 leak
  39. 73-77 Compatible Double hump Trans Members
  40. Tremic 5 Speed Conversion
  41. 1956 Jetaway won't shift into 4th
  42. Transmission Mount/Driveshaft Issue
  43. Input shaft on M20
  44. Stator Solenoid
  45. TransGo do it yourself auto shift 4L80E
  46. M20 tail shaft bushing and seal part no.?
  47. Backdrive linkage
  48. Auto trans Oil Replacement
  49. TH350 to 200-4R swap: cable question
  50. Transmission Dipstick Tube Support Bracket
  51. 93-97 F-body T56 conversion in a 70 S 455/400
  52. 67 jetaway into a 65 cutlass!
  53. Hydramatic question
  54. 1965 th400 filter change.
  55. TH350 Modulator
  56. Another 200-4R question
  57. Transmission change
  58. 1957 Oldsmobile 88 Jetaway Transmission Filter
  59. looking for advice
  60. Muncie shifter selector post
  61. Hurst Shifter Info 68 442
  62. 1979 HO w30. Will this fit
  63. 70 OG tag id
  64. Hydramatic shift problem
  65. Bolt circle size
  66. Jetaway not shifting from 1st gear
  67. Question RE TH400 fluid cooler lines
  68. TH350 fluid?
  69. About an oil leak on my transmission
  70. 1957 Oldsmobile Jetaway Hydramatic Transmission
  71. mcleod clutch kit
  72. 63 super88 394
  73. Dual Gate Shifer
  74. TH350 kickdown was deleted?
  75. Transmission lines
  76. TH350 hesitated under mild acceleration
  77. M20 drain and fill
  78. Cooling Brass Line Fitting
  79. TH400 question
  80. 1992 700r4 Question Custom Cruiser?
  81. Automatic Overdrive Transmission Advice
  82. BOP bellhousing for 4L80E
  83. Speedometer cable slack
  84. Flywheel
  85. Column Shift to Floor Shift
  86. 69 floor shifter
  87. I’m buying a lottery ticket!
  88. Metric 200 install with a 1962 215 in an F85.
  89. 67 442 - car doesn't stop after shifting in park and makes clicking noise
  90. 69 442 transmission paint
  91. Oil Pushing out of Transmission Dipstick
  92. New TCI transmission pan install affects floor shift cable alignment
  93. Turbo 400 kick down question?
  94. Transmission Questions
  95. Converter Identification Question
  96. Linkage diagram..
  97. 8 Speed Possible? 8L90? 10L80?
  98. Tremic TKX Fluid
  99. To replace or not to replace the speedometer cable?
  100. Governor pressure not overriding detent pressure
  101. '62 F-85 Conv 215 TH200 info needed
  102. TKX in 1964 Cutlass
  103. Trans line fitting..
  104. 200r4 won’t shift out of reverse and now reverse too
  105. 1948 Olds 76 hydramatic drive shaft seal
  106. Factory WOT shift RPM 1986 442
  107. 350 turbo shift cable length?
  108. Bad Torque Convertor
  109. is Dexron Vl/Merc LV ok to use??
  110. TH400 Valve Body
  111. OW Trans 1971w30 th400
  112. shifter
  113. 59 Hydra matic lost 3rd and 4th gear.
  114. Shift indicator question - Cutlass 76
  115. 1984 TH200 Transmission Leak
  116. Manual bell housing preference
  117. TH350 rebuild
  118. Hard to get into reverse
  119. Hughes GM25HD converter size
  120. Looking for a seal
  121. Long tail th400 in cutlass
  122. Help with 200-4r
  123. TH-400 Shift points and how to do it right!
  124. Transmission exhaust bracket spacer size
  125. Tremec Install Experiences and Crossmembers
  126. TH400 no kickdown
  127. Are all TH400 governors the same?
  128. Speedo Housing 400 TH
  129. THM 325-4L transmission
  130. Dual gate shifter handle R&R
  131. Which speedo gear ? 74 cutlass th400
  132. Broken shift control cable on 1992 Toronado
  133. 3 speed does not shift
  134. bad parking pawl?
  135. Help touble shooting 2004r No Lock up
  136. Upgraded from Jetaway to TH-350 questions
  137. Slim Jim to th350 or th400
  138. 700r4 in my Starfire
  139. Speedo cable not working
  140. Torque converter
  141. TH200c lockup connector unplugged
  142. Torque converter sith stall recommendations
  143. Muncie M21 Side Cover
  144. Counterfeit Trabsgo 4L80E HD2 shift kit
  145. Transmission not shifting out of low gear
  146. LS engine & TH400
  147. M20 sqealling and grinds going into reverse.
  148. transmission leaking
  149. TH-350 Swap - this month
  150. 1987 Oldsmobile 442
  151. ATF overfilled?
  152. Pulled the trigger on TCI 2.75 first gear 4L80E
  153. Yoke leaking?
  154. TCS and kickdown switch on trans...
  155. Switch Pitch 400 Question
  156. 1987 Cutlass Supreme TH200c to TH350 swap
  157. Trans Swap - Future Planning Question
  158. Infernal dipstick tube TH350
  159. Change vac switch Setting on 200-4R Transmission
  160. Dual Gate Install in a 1969 442
  161. TH350 no third gear
  162. Is this the BOP version of the TH-350?
  163. Transmission options for the '64 Starfire
  164. 1955 olds hydromatic question
  165. Transmission leak
  166. 67Jetaway possibly dead
  167. '71 W-30 with W-37 clutch option
  168. higher stall converter with th200-4r on 1968 463 Cutlass
  169. 1966 oldsmobile cutlass kickdown wiring
  170. Leak
  171. 1966 jetaway questions
  172. 200-4r value
  173. Leak in braided SS line for hydraulic throw out bearing
  174. Modulator stipe colors?
  175. Th400 vent tube
  176. When do you need a higher than stock stall converter
  177. Ongoing Hurst Dual Gate questions
  178. Transmission swap - 64 Dynamic 88, chevy auto for slim jim?
  179. 69 cutlass S 350 tranny swap
  180. Clutch pedal bracket, different or the same as an automatic?
  181. Rebuild Thoughts
  182. 1970 Cutlass TH350 to TKX parts list
  183. What Transmission is This?
  184. 69 4 speed linkage
  185. Clutch fork and throw out bearing
  186. Ran engine 5 mins. with Jetaway super low on fluid
  187. 1979 Trans issue
  188. jetaway tranny throttle control switch
  189. Muncie M22 or Tremec TKX 5-Speed?
  190. All that is needed for a 4L80E swap in a 70 Cutlass S
  191. Its a ROTO 5 Christmas
  192. 200R4 speedo bullet insert stuck
  193. Dual Gate Mounting Position
  194. Pan mounted shift cable mount
  195. Transmission upgrade
  196. shifter linkage play/ reverse lights 69 cutlas
  197. The 200R4 Install
  198. Th350 Torque converter
  199. Torque converter won't turn once the bell housing is tight
  200. 1950 oldsmobile transmission modulator valve
  201. 700r4 into a 1975 Delta88
  202. Torque Convertor Clearance Issues
  203. 72 Tranny pan leak
  204. Rebuilding a TH425
  205. Early shifting 67 400 switch pitch
  206. Torque converter to flex plate distance
  207. Looking for BT-33-1
  208. 67 Switch Pitch TH400 late shift
  209. z bar questions
  210. Richmond Gear vs Muncie
  211. 4l80e question
  212. 71 cutlass supreme
  213. Questions about 394 flywheel…
  214. ST300 vs. TH400 lines…?
  215. Death of a 4t60e!
  216. diesel engine manual transmission swap
  217. Transmission in My 72 442
  218. Speedo Bounces
  219. Neutral safety switch
  220. 68 442 overdrive
  221. stock turbo 400
  222. T350 tear down
  223. 1972
  224. Unknown transmission
  225. Switch Pitch 400 Identification
  226. Psa: No more 4 speed cases
  227. 2.75 first gear TH350
  228. Tailshaft is destroyed in my 200R4
  229. 1961 Dynamic 88 trans fluid leak at speedo cable connection
  230. Th 400 problems
  231. TH400 Switch Pitch Drama
  232. 1967 Cutlass Supreme Clutch Pedal
  233. 68 442 Post coupe swap suggestions.
  234. 200-4r questions
  235. Roto5 Hydramatic
  236. 1972 442 pops out of 2nd
  237. What am I not getting 😕?
  238. 1975 Cadillac TH400 with long tail shaft
  239. TH400 leaking 1-2 quarts once parked in driveway after driving
  240. Speedo drive gear coming off
  241. 2004R "over sensitive" torque converter
  242. Roto 5 TV Adjustment
  243. ST300 cooler lines
  244. Th200c Speedo gear
  245. Hurst Shifter Rods
  246. Floor shift cable BRACKET ID QUESTION
  247. 324 clutch
  248. 69 442 Manual to Automatic
  249. Flexplate torque procedure
  250. Auxiliary Transmission Cooler for 1980-90 Custom Cruiser
