- 1986 Cutlass T-Top 442 Shift cable
- 2004r
- Standard or Dual Gate Shifter Cable?
- 72 CS Transmission Issue
- olds automatic transmission options
- Trans cooler.
- 200r4
- 1955 Hydra Matic issue. Stuck in park
- TH400 pool of transmission fluid - cause?
- 200-4r rebuild kits
- Decode my Muncie
- Converter stall recommendations
- 700R4 governor recalibration success
- installed a 200R4 in my 64 F-85 post car
- Lakewood Bellhousing Install
- TCI Breakaway Torque Converter
- Speedometer gears!
- Fluid puddle
- Another Jetaway to T350 Question
- Towing a 76 Omega
- 67 th 400 switch pitch odd behavior
- Z Bar Bushings
- TH 400 not shifting
- TH400 Extended Filter Pickup Tube
- TH400 kickdown
- Aluminum trans cooler vs tube type
- TH400 Slips in second gear when hot and conversion to new-style filter
- 1967 Toro Transmission HELP!
- Which TH350 transmission??
- Found TH700, does it fit?
- Transmission Fluid
- Torque Converter Seating Issue
- Richmond gear trans
- TH200 4R in a ´66 F85
- 200r4 another question!
- Re building a th350
- Olds 3speed
- 4l60e/70e/80e
- 67 cutlass with 2 speed auto
- S=Super!
- 455 To 4L60E Adaptor plate
- TH350 Trans help
- 700 r4
- looking for technical detail of manual trans swap without drilling the crank
- 67 Switch pitch converter id
- TH350 Leaking Around Speedo Input
- M-14 Case Number
- ST-300 Tail shaft bushing questions
- Shifter Knob Color
- ATI transmission
- 2004r lockup or non lockup?
- '68 Cutlass with 200 4R
- 200-4r console shifters
- 1969 442 4-speed M20
- I received a free Trans
- 1970 Driveline swap
- Converting TH350 linkage??
- Trans 350 question
- switching from a turbo350 tranny to a 200r4?
- 200r4 vs 700r4
- 2004r Forward drum
- 2004r finally in!
- Removing Speedometer Gear/housing
- Correct 4spd for 1972
- TH400 cracked
- Aftermarket Shifter for TH-300 Jetaway Trans
- Anyone with a 394 V8 4 barrel carburetor engine
- Quick Speedometer Cable Question
- Transmission Flush?
- Switch Pitch 400 or 200
- 1962 Dynamic Tranny shifting bad.
- 200-4r quadrajet linkage
- 65 jetaway trans fuse blowing
- Leaking ATF out of the u-joint??!!
- Trany mount
- 200R4 w.o.d VS 400R4 w.o.d
- 4-speed Transmission Question
- Tremec vs Keisler
- Dust Cover
- Cross member insulators
- Where to attach clutch return spring w/ Headers installed
- Th400 rebuild..
- 4 speed to a non 4 speed crank?
- 1941 Hydra-matic down shift
- 1959 oldsmobile transmission dip stick access location
- First drive with the 72 Cutlass, trans shifting odd...
- Tranny Leak
- 1964 Cutlass Transmission
- Differences in Dual Gate Shifter Cables?
- Possible for '78 floor shifter in '65 Cutlass
- 1971 442 OG TH400 Factory Specs
- How to drain a trans properly
- 67 4 speed setup
- C5 Stamped on Transmission
- Decoding TH400 Plate Number
- kick down cable?
- '71 M20 from Nova in '70 442?
- column shift crossbar question
- Factory 3-speed vs. 4-speed clues?
- Torque converter differences
- Turbo 350 Shift Points WOT?
- Automatic Floor Shifter - Performance Gate
- General TH400 questions
- Need a switch pitch --
- TH400 Kickdown Assembly
- 700R4 in 1964 Cutlass?
- transmission Help
- 200r4 Conversion Question
- More 57' Transmission questions - STUCK! HELP
- possible tran issue need help diagnosing th400
- Jetaway Passing Gear?
- 200-4r running hot problem solved.....
- 55 Olds Holiday with Transmission Issue
- newbie question - how to remove trans dipstick
- '69 Turbo 400 kickdown
- Console shift cable adjustment
- Bell housing bolt spacing why?
- 200/4R choices
- 200-4R transmission running hot........
- Reliable transmission conversion for 63 Cutlass F-85
- Olds 98 1971 - transmission
- Adaptor Plate
- filling an empty th350
- Trouble shooting torque converter?
- Dual Gate Shift Cable
- Th400 spitts oil from filling tube!
- Ebay flywheel
- need help, column to floor shift conversion 1969 Cutlass. I am at a lost
- '70 442 TH400...tail length?
- Jetaway to TH350 swap help
- Newbie with a trans question...
- Any Recommended Rebuilders in NC/VA/MD? TH400
- Flat towing a '75 Omega SX 5 speed
- Transmission Help
- '67 Toronado Tranny won't engage after filter change
- How long does a rebuild last?
- Help with removing th350 from 70 cutlass
- Slim Jim parts needed
- New clutch slipping
- Clutch Addjustment
- I need a shifter 70-72 for console
- Muncie rebuild
- Transmission makes a clunk when put in drive..
- Fluid spitting out from Dipstick 68 Delmont 88
- transmission id problem
- Kick down problem...
- Need Help With TH350!
- 4 spd conv. parts
- 72 Olds Cutlass Supreme have drive no reverse
- Throw Out Bearing
- M22 rockcrusher
- Need TH350 Trans Cooler Lines, Who likes ILT?
- 200r4 vs 700R4
- Help to I.D. Hurst shifter
- Stock 350 torque converter
- need advice 2004r
- Muncie I.D.
- New Clutch
- Whil I'm patienly waiting for my........
- Th400 rebuild NYC
- 200-4r Governor Replacement
- Please help me choose the right torque convertor!
- Jetaway switch pitch switch
- 4L60-70-80 for 455 Olds
- Roto Hydramatic problem
- Hurst His/Hers Shifter With 200-4R OD Trans
- B.O.P Th400
- 1958 Jetaway Casting Numbers Questions
- auto speedometer exit
- Replacement for 2 speed trans
- 86 Olds Supreme transmission question???
- Trans differences mid 50s
- Tranny line repair
- Shifter for '67 4 speed?
- neutral safety switch
- TH400 ID Tag decode?
- Solid motor mounts and 4spd?
- Neutral safety and backup switches 67 MANUAL
- 71 cutlass 2004r
- jetaway to 4spd conversion
- Best Street/Strip Clutch
- Where to get a stock TH350 Master Rebuild Kit with Torque Converter and Bushings.
- What is everyone's opinion on these options?
- th400 odd whining sound.
- TH400 Stock TC Stall
- Which Speedo Gear?
- 2004r manual shifting question
- 64 Delta 88 Fiesta Station Wagon-no moving
- Switch-pitch conv. on 1970 Toro / TH425
- TH400 Dip Stick
- 71 cutlass wont go forward but will go in reverse
- What brand\model of fftermarket Floor Shift do you like
- 76 cutlass 200-4r tranny swap
- 72 cutlass th400 factory kickdown wiering
- Th200 4r id
- 1963 f-85 TH200c tranny swap
- where to find 2004r
- 66 f-85 330cid..Trans swap??
- Transmission id?
- 1970 455 with t400
- 1971 Cutlass TCI transmission opinions
- 200R4 builder near St Louis
- 455 with TH400 to an overdrive What is my best option?
- Tunnel hump for 1966 442
- 72 cutlass wierd shuddering/jerking
- Has anyone used OPGI for 200-4R?
- Dual Gate Dust Cover
- Tail Shaft
- knowing what trans i have?
- '68-69 jetaway shift cable length
- 1970 Rallye 350: Crossmember different TH400 to TH350?
- A/T Floor shift cable length?
- little trans help.
- 5 Speed Update
- I think I bought the wrong flywheel?
- Flexplate interchange for 455
- hydro swap
- turbo 400
- Need Flywheel Help
- th350 trans stock lock up stall converter?
- Understanding T400 Transmission Kickdown Switch
- ST-300 questions and durability
- Oh No - I Think I Was Shipped The Wrong 4 speed Hump - And It's Already Installed
- Keep it Auto or 5 Speed
- Replacement TH350 - need opinions & some advice
- 1970 toro transmission question!
- 18 t steel speedo "drive" gear needed
- Converter Swap Turbo 350?
- 64 roto slimjim
- my monster transmission review and help needed
- Tranny Leak 72 Cutlass 350
- TH400 Elec Kickdown
- Transmission cable bracket
- Transmission cooler '69 Cutlass
- And yet another 200R4 question...
- Looking for TH350 technical information
- Trans and rear swap
- '68 Jetaway question
- Auto to T5 Manual Swap Help Please
- 71 cutlass vert 350 stock floor shifted 200r4 swap
- Lightning Rod Help ??....
- 62 Starfire trans. swap
- Anyone gone with a T5 Transmission?
- 1971Console shifter
- Need dimension from the pilot bearing hole
- TH400 cooler line routing
- Muncie transmission swap
- Th400 id
- Trans "Reprogramming"
- Transmission accumulator seal
