'67 Toronado Tranny won't engage after filter change
Old Apr 22, 2013 | 05:19 AM
schaferak's Avatar
After changing the filter and gasket in the TH425 the transmission won't engage until it's completely warmed up and then it needs to be revvved up to engage. The intake pipe/filter doesn't seem to "snap" into place like the guys at the parts store say it should. The o ring in in place. Any suggestions?
Old Apr 22, 2013 | 06:06 AM
1. Get your filler tube properly engaged in the transmission body. It doesn't snap in but should press in firmly and then be retained by the bolt through the hole in the "flag" higher up on the tube.
2. Check your fluid level and add fluid until you have enough in there.
3. Welcome to Classic Olds!
Is it full?
Old Apr 22, 2013 | 06:18 AM
schaferak's Avatar
Thanks, I didn't realize there was a bolt that helped retain the tube. I'm going to head out there and put it back together. I'll let you know how it goes..Thanks again!
Old Apr 22, 2013 | 06:20 AM
Yes - somewhere along the length of the tube is a tab or "flag" with a hole in it, and there should be a ¼" (or was it 5/16"?) screw through the hole in the middle into the back of the engine, which holds the tube in place from side to side, but also holds it down in the hole, so the O-ring can seal it.
Old Apr 22, 2013 | 06:27 AM
schaferak's Avatar
Oh, I wasn't clear on my problem. I was referring to the the fluid pickup tube/filter assembly. The one that came with the new gasket. Sorry.
Old Apr 22, 2013 | 06:37 AM
Oldsmaniac's Avatar
1st question as already asked is did you fill it with enough fluid??
stevengerard
Sep 10, 2014 03:17 PM
blacksupreme
Apr 8, 2012 07:17 PM
coldfire
Mar 22, 2012 10:36 AM
Regent_C
Jan 22, 2012 08:06 AM
rlafash
Oct 24, 2010 11:23 AM
