1964 Cutlass Transmission
Old Jul 5, 2013 | 12:38 PM
Threejdsolds's Avatar
I acquired a 1964 Cutlass two door hardtop, AC car that I hope to restore. It is a manual transmission car , but the trans is out of the car. There were two trans in the trunk. My buddy says one is a " T-10" 4-speed and the other is a 3-speed. Is there a way to know from the cowl tag what trans the car came with ? Attached are pictures of the T-10. Can the trans be identified by the numbers ? Thanks for the help , John
Old Jul 5, 2013 | 12:59 PM
classicmuscle442's Avatar
Trans
The three speed would be more likely correct on early cutlass, T10 is actualy a Ford trans, but fits the bellhousing and would work.
Old Jul 5, 2013 | 06:20 PM
The numbers on the 3 speed are (1)case : 3858986 A206 (2) shift cover : GM21 3852646 H136 (3) tail housing 3860042 GM
Old Jul 5, 2013 | 06:53 PM
I can tell you for sure that the T-10 is NOT the original trans, since Olds stopped using the T10 after the 1963 model year. The factory four speed would have been a Muncie. The three speed may or may not have been original, there's no way to tell from the cowl tag. The shifter is not original, since 1964 cars used a Muncie shifter, not a Hurst. The bellhousing in the picture is a Chevy bellhousing and will not bolt to an Olds motor. If the final picture is the T-10 input shaft, that is a GM case, but not a trans used by Olds.
Old Jul 5, 2013 | 07:58 PM
2blu442's Avatar
Hi John
Is this a recent addition to your 1964 collection?
The T10 tailshaft looks to have a date code cast into it. If I'm reading it right it looks like 6 10 61. Do you have any pictures of the 3 speed? I've got one I picked up years ago that has a cast iron housing rather than aluminum. Hopefully someone will be able to key out the numbers you've posted. The 1964 in my picture came with a console and that option was listed on the cowl tag. If you have a console or parts from one look to see if it has the 3 speed or 4 speed pattern on it. You probably didn't get a console, but I wanted to mention that just in case its in pieces in a box somewhere.
John
Old Jul 5, 2013 | 08:06 PM
Thanks Joe. Any way to tell what car the T-10 came out of ?
Old Jul 5, 2013 | 11:48 PM
Hey John, how are you ? I hope it is cooler in Medford than down here. Listed numbers for the 3 speed in this thread. It is an iron case. Attached a couple of pics of the automatic hardtop with the 425 I got from you. Thanks again for your help. John
Old Jul 6, 2013 | 05:32 PM
Spent some time on the internet trying to ID the T-10 trans. Appears to be 1961 Chevy , either Corvette or Impala. Definitely not Olds. Still trying to research the 3 speed numbers.
CRH
Jan 30, 2018 09:27 PM
64oldsf85cutlass
Body work
Jul 4, 2014 07:06 AM
2blu442
Dec 16, 2013 07:14 AM
1964OldsmobileF-85V84Door
Sep 24, 2008 12:09 PM
