200-4r running hot problem solved.....
Old Jun 7, 2013 | 03:34 PM
1970-W30's Avatar
For you guys that had been following my earlier thread about keeping my new 200-4r cool, this is what cured the problem. After a week or so with an auxilery cooler installed, the 200-4r is no longer running hot anymore. I hooked up a Flex-A-Lite 4126 cooler, it's about 10" x 20" in size, big enough to do the job but not so big that it would be hard to install. It came with 1/2" spacer blocks and push rods for mounting and all but two fittings that I had to buy.
The factory cooler lines are 5/16" and the outside cooler 3/8" so I bought a 5/16" compression fitting on one end and 1/4" pipe thread on the other end for the 3/8" hose barb. Pretty simple installation. Been having 100+ temps lately, trans stays around 180 or so. So, if your thinking of upgrading to a 200-4r transmission, you might as well budget for a decent auxillary cooler also.
Old Jun 7, 2013 | 04:14 PM
Did you plumb it through the radiator also?
Old Jun 7, 2013 | 04:35 PM
1970-W30's Avatar
Yes, first the radiator then thru the cooler.
Old Jun 7, 2013 | 04:50 PM
The 200-4R is very susceptible to heat and the stock cooler is woefully inadequate. You made a good choice for trans longevity. For my Custom Cruiser I snagged the factory aux trans cooler and lines from a similar Caddy Fleetwood.
1970-W30
19
Jul 5, 2013 05:36 PM
Joe Hatton
Feb 17, 2013 09:21 AM
MN71W30
Sep 13, 2010 06:47 PM
1965cutlassragtop
Jun 21, 2010 09:30 AM
dhartley72
Mar 15, 2010 08:12 AM
