need a electrical issue solved
Old Mar 14, 2010 | 08:58 AM
dhartley72's Avatar
Unhappy need a electrical issue solved
when i connect my battery ..my tail lights comes on and wont go out unless i disconnect my battery..any ideal what it can be?
Old Mar 14, 2010 | 09:08 AM
Don L/442's Avatar
If tail lights(running lights) check light switch in dash
If brake lights check brake light switch at peddle.
Old Mar 14, 2010 | 09:19 AM
dhartley72's Avatar
okay will check now...its the runnings lights...also the blinkers are not working....seem to stay solid....maybe a bad bulb?..by da way thanks Don L/442
Old Mar 14, 2010 | 10:34 AM
66ninetyeightls's Avatar
Land Yacht Captain
Its one of two things. Either a faulty switch or a short in the wiring. Bust out the wiring diagram and figure out which it is. Its an extremely easy circuit to diagnose.
Old Mar 14, 2010 | 11:13 AM
dhartley72's Avatar
thanks 66ninetyeightls........
Old Mar 14, 2010 | 03:58 PM
OK, first, how did you determine that the problem is the tail lights and not the brake lights? I ask because the turn signal wiring is part of the brake light circuit - they use the same filaments in the bulbs. If the turn signal wiring or switch in the column had a problem, it could account for both of your symptoms.
Old Mar 14, 2010 | 04:05 PM
70 cutlass s's Avatar
I have a question? The brake lights switch is wired hot all the time. For the running lights to come on the key would have to be on. So for the blinkers to work the key would have to be on.
Have you check the blinkers with the key on. If the tail lights are on when the battery cable is hooked up then it sounds like the brake lights. That would make me think brake light switch is bad or needs to be adjusted.
Old Mar 14, 2010 | 04:32 PM
dhartley72's Avatar
okay i changed out all the fuses and bulbs....the issue with the turn signal is ressolved it was the bulb.... its the tail running lights....because when i push the brakes it lights up brighter......i guess my next option is da switch
Old Mar 14, 2010 | 06:17 PM
Lady72nRob71's Avatar
Pull the TAIL fuse and see if they go out. If so, the switch would be the next culprit. If they stay on, then there is a short elsewhere in the circuitry.
Old Mar 14, 2010 | 06:32 PM
dhartley72's Avatar
dats a great ideal.... i didnt think of dat....i will try first thing tomorrow....wish me luck.....thanks again
Old Mar 15, 2010 | 07:37 AM
Nope, that is not correct. Both the brake lights and the tail lights (and headlights) work without the key. The turn signals do require the key, but the brake light wiring passes through the turn signal switch. Consult your chassis service manual.
Old Mar 15, 2010 | 08:12 AM
Yeah your right. I don't know wth I was thinking or wasn't thinking.
oldspackrat
Apr 26, 2014 04:38 PM
Fred Kiehl
Vista Cruiser & Wagons
Mar 11, 2014 01:04 AM
Joe Hatton
Feb 17, 2013 09:21 AM
MN71W30
Sep 13, 2010 06:47 PM
1965cutlassragtop
Jun 21, 2010 09:30 AM
