Olds 98 1971 - transmission
Old May 21, 2013 | 10:45 AM
wojmar's Avatar
Landyacht Ambassador PL
Hello
I have a problem with the automatic transmission.
After a four-month winter stop, long stretches 1-2 2-3.
It does not change gears smoothly.
Oil and filter set today. Unfortunately, it did not help.
What else could go wrong at standstill? In the autumn the car drove perfectly.
Please help me. My mechanic says something about the pressure regulator. Is this true?
Old May 21, 2013 | 10:49 AM
You can double check the vacuum line to your modulator. It should go to manifold vacuum.
Old May 21, 2013 | 10:52 AM
76 Regency's Avatar
That was my first thought as well. Check that your vacuum line is connected and the hose is in good condition. You may also want to check that all of the vacuum lines are connected properly and in good order. If all check out, you can also easily change the vacuum module on the transmission. They are readily available online.
Nice car!
Old May 21, 2013 | 11:06 AM
wojmar's Avatar
Thank you for the quick response.
On Monday I go back to the mechanic.
Now I know what to talk to him.
Old May 30, 2013 | 12:46 AM
wojmar's Avatar
Yesterday finally stopped raining and I went to the garage.
The problem was very simple. Rubber hose burst at the modulator.
Thank you again.
Old May 30, 2013 | 05:52 AM
76 Regency's Avatar
Thank you again.
Awesome...glad you got her running right again! Enjoy cruising as much as you can in that fine ride!
anthonyP
Jul 1, 2013 03:09 PM
Gunmars
Jan 13, 2013 03:17 PM
dsolomon
Jan 22, 2011 01:12 PM
dallasite21
Jan 20, 2010 09:31 PM
spherion1
Apr 13, 2009 03:04 PM
