- trans question
- corvette zf 6 speed in 68 442
- muncie vin stamp
- THM 350 Delayed Shift Into Drive
- th 350 shift kit
- TH350 not shifting to 3rd
- 4l70e/4L75E/4L60E
- Need '71 Cutlass Supreme kickdown cable 350 turbo
- Delta 88 1969 transmission ??
- Need new torque converter but what size...???
- Anyone running a 700r4 trans in a 72 cutlass?
- 71 350 to 4l60
- Hurst shifter handles?
- Rebuilt 54 transmission - shifts hard
- 67 Delmont 88 4 Speed Conversion
- which tranny
- th425 550hp /600 tq
- Putting a T-5 in a 63 Cutlass pictures
- Transmission & engine problem on my 57
- Identifying '68 OW valve body
- 1968 442 crossmember removal….its stuck...
- 57 Jetaway info needed
- Tail shaft questions
- Speedometer issues 1956er
- Transmission, restomod 5 speed choices? HELP
- 1970 Cutlass Supreme
- Dohh damaged torque convertor ?
- Transmission Chain Toro from70`s
- How to adjust 3/4 hydramatic shift
- TH400 or hydramatic
- Speedo cable
- Speedo Problem
- T56 installation in a 1971 Cutlass.
- No forward gears
- shifter adjustment
- tranny dilemma
- 2004r
- What transmission do I have here?
- Speedo cable
- B Body Turbo 400 Speedo Conversion
- How do I get rid of this? TCS, transmission switch
- Muncie m20 need to sell has extras. need advice
- 1971 350 tranny swap?
- Tranny fluid for 83 Hurst THM200-4R
- Trans Adaptor
- th350
- Th350 swap to 4-speed?
- Where to find a manual tranny for 1962 cutlass??
- Which Transmission in 84 Oldsmobile Delta 88?
- Automatic 200-4R shift issues
- Anyone know a transmission guy near Austin TX??
- 455/200r-4?
- Lil Sis has an extreme KALunk
- Which automatic transmission?
- st300 - Missing a wire
- Lost leaking trans thread.
- 1970 OG Rebuild in Austin
- '79 H/O Transmission Cable Bracket
- Rebuild a Hurst Shifter??
- Crankshaft bushing for auto to manual conversion
- Speedometer Offset Adjustment?
- help to find a part
- 200-R4 question
- Torque Converter Identification
- 68 cutlass kickdown
- Th350-200r4 flexplate?
- Turbo 400 brackets
- What to do!!!!!!! Saginaw 4-speed info please
- stall converter speed
- shift kits
- Weird leak th400
- C4 Transmission in 72 cutlass supreme?
- Shifter change from 2 speed to 3 speed
- Rebuilt TH400 problems. No park and leaking
- Will this part fit my 442?
- 4L60E in 70 Cutlass
- Can you run a TH400 with a Olds 350 motor?
- want to put a shift kit in my th350 trans for my 1970 olds 350
- trans shop says they can change the stall in ur converteur
- TH400 Case Finish - Is This Acceptable?
- stock convertor
- Finding a replacement selector shaft and valve body bolts for a TH400
- Opinions on 200r4 swap
- Help on 57 Olds trans repair
- Best stoplight trans
- 4l60e/4l70e
- 1969 442 w/ 455 700r4 HELP!!!
- transmission lines
- Will a TH200-4r bolt up to a Buick 300
- 215 v8 mods for modern transmissions..what will I have to do?
- Gear oil?
- 71 Vista Cruiser transmission
- Need an expert on the 2004r
- Airworld Transmission
- TH400 rebuild
- downshift cable too long?
- Do I need to have kickdown cable TH350
- TH 400 problems
- DM Transmission Fluid
- Another speedometer gear mystery
- Auto to 5 speed?
- Trans Shop
- jetaway trans. center console shifter swap
- Any suggestionson next course of action
- Need help keying out Muncie 3 speed manual transmission
- Shift Kit for TH-350?
- Muncie questions
- need help
- 1963 cutlass f-85 need to update transmission.What can I do?
- Jetaway > 200-4R Swap: Misc things to look out for
- Trans Fluid
- Bad transmission or torque converter?
- TH350 rebuild kit recommendations
- OEM Hurst shifter ID.
- need help
- Downshift cable linkage
- need more gears!!
- Do you know what this is? (funny)
- downshift cable leak....help
- Speedo cable leak at trans
- Transmissionfluid
- Th350 shift kit
- Th200 transmission
- Tranny cooler
- TH350 late shift into 3rd and shaky reverse
- 66 starfire
- OW & JO Transmissions looking for there cars & code confirmation
- 70 W-31 JO th350 transmission
- TH350 transmission mount dilemma, and some leaks
- HELP newbie needs help with TH350
- tranny cooling line problems?
- Which color plastic speedo gear do I need?
- Jetaway Transmission
- Backyard shed mods for a TH400
- 1953 Hydramatic problems N D S L R
- TH 350 seems to shift very early
- Trans doesn't go into gear when first start up
- Torque converter screw up
- new rear end or new transmission?
- Squeaky TH400
- Sprag broken
- Stall Converter
- 200-4R Lockup During Drag Run
- Add speedo gear drive to a Delta trans
- 200R4 Lock Up Non-Lock Up Confusion
- 200R4 Ident
- 1955 Hydramatic Shifting
- 400 Long tail
- 67 442 Auto Speedometer Drive Gear
- 200 4R externel filter and cooler
- 200R4 Ready for Rebuild
- How much oil
- Modulator vacuum line
- TH350 won´t shift out of 1st
- Looking for a th 400 for my 455..need suggeestions
- Clutch adjustment
- Shift kit
- Put a T350 on a 65 330, what do I need?
- setting up a kick down cable.
- Can anyone help me decipher these numbers?
- Just ordered my new shifter
- Trans Coolers
- Will converter flash higher behind big block?
- Transmission Tunnel Reshape
- Identify a 70 OW trans
- Kick Down on 57 Hydramatic
- trans ID help
- Cost of a manual swap in a 3rd gen cutlass?
- It looks like a transmission...
- Painting the case
- Leaking Shifter Seal 400TH
- M 23 4 speed trans
- Downshift Trouble on '66 Toronado
- th350 rebuild
- Is this a good deal?
- TH-400 Leaks When Sitting
- Turbo 350 Tranmission Live behind a 455
- front seal look good?
- 84 olds xmsn
- Question: Hurst Straight Rod Shifter
- M41 Info Needed
- muncie shifter
- Transmission mount question
- Slim jim questions
- Shift Kit Question
- Switching Auto to Manual
- 62 f85 cutlass tranny help
- 200r4 in a 64 f85 any help
- Going to keep this clean guys and gals now A torque convertor ?
- Trans Cross Brace
- New guy needs some help
- Jetaway (ST300) Pan Gasket?
- 70 4speed setup into 67 Cutlass ?
- tko600 twisted yoke splines
- 1970 442... school me on 4 speeds, please!
- Torque Converter question
- Whining When Clutch is Engaged
- Hughes Performance
- Th350 with 2500 stall?
- 62 f85 with th350?
- Lost park... then lost reverse
- 4Speed Trans Rubber Mount too high?
- th350 wont shift into first on its own
- Crossmember location with saginaw trans
- 1970 Delta 88 Auto to Manual Transmission?
- Transmission was starting to slip!!
- power glide
- Is there a clutch lockout switch in 68?
- 5 speed options
- Speedo Issue
- Aux trans cooler.
- 1970 Manual Transmission
- What auto trans did a 1965 330V8 Cutlass Sports Coupe when it left the factory?
- More 200-4R questions
- Slip yoke for a TH400 BOP swap in...
- Anyone knows Transmission Rebuilder in Texas (Slim Jim)
- Trans swap for '61 Super 88 ?
- Jetaway Hydromatic rebuild questions
- 68 Cutlass Supreme 2 Speed Jetaway fluid changing
- early th400 filter
- Dip stick
- which is a better 6 speed ratio?
- Mag-Hytec TH400 transmission pan
- Overdrive
- stock 200r4 too weak? 8.5-1 350 stock cam 3.42 gear
- '71 442 Slip Yoke & Universal
- t400 sitting since 1986.....gotta rebuild?
- Gear star transmission
- 455 Flywheel
- Jake is a stand-up guy
- !971 olds delta 88 royal
- 1972 Cutlass 455 with Tremec t 56 Magnum
- Rechroming A Dual Gate Blade
- 1972 CS Acceleration Problem..
- 67 Cutlass Sedan Jetaway to Th350 swap
- 62 olds starfire tranny
- 1957 olds 88 trans. lines
- Tremec Tko 600
- Rear axle identification delta88 ´75
- Has anyone put a 4 speed behind a 394?
- 260 to 403 flywheel 5 speed?
- 71OG Torque Convertor Specs
- Kickdown Cable...
- 4l80e to a 350 olds
- Tranny Fluid
- Another 55 Hydro
- 4l60e/70e/80e
- slim jim
- what tranny to go with and why?
- Aluminum flyhweel
