Aluminum flyhweel
Old Nov 7, 2013 | 07:35 AM
brownbomber77's Avatar
Aluminum flyhweel
Anyone used one yet? I'm curious about how it reacts on a 455 as I was considering one for my build. I loved the way it moved on my 302 powered Fox body and even my 408CI truck. I figure the Olds 455 has enough bottom end to get it outta the hole in regular driving but just curious if anyone has tried it yet.
Old Nov 7, 2013 | 08:31 AM
It all depends on vehicle weight, gearing, and engine torque. The torque is no issue, but in a heavy vehicle with low numeric gears, it probably isn't a benefit. In a lighter vehicle with high numeric gears, it reduces rotating inertia so the engine gets into the power band quicker.
Old Nov 7, 2013 | 08:58 AM
I get the physics, I'm curious if anyone has run one before on a 455. I imagine if someone did run one, it wasn't on a 2.41 geared Vista. haha I've got a 3.73 under my '77 coupe, so I'm hoping it wouldn't bog...
Old Dec 22, 2013 | 02:06 PM
odddoylerules's Avatar
...into the powerband? These engines dont need to rev to accelerate, when torque peaks at 3000 rpm....
Old Dec 22, 2013 | 02:08 PM
on a tighter wound small block I would expect more benefit in a properly set up application, as an engine like that would benefit from being free-er to spin up. With a heavy vehicle, big torque and a heavy flywheel will provide more acceleration off the line, ALL THE TIME
tocicar8825
Sep 21, 2021 07:10 AM
denis
Drivetrain/Differentials
Feb 13, 2007 03:36 AM
blonzz
Oct 25, 2004 02:19 PM
