1972 Cutlass 455 with Tremec t 56 Magnum
Old Dec 3, 2013 | 11:35 AM
SRV8's Avatar
Hello,
my name is Joerg from Germany and I need some help.
I plan to install a Tremec T 56 Magnum in my 1972 Cutlass convertible 455.
Ok so far i let the crank prepared to take the pilot bearing.
Does anybody installed already the T 56 behind the 455, around 550 HP
I got some questions, hope someone can give me an advice.
I know I need a special flywheel housing, which is a good and affordable one.
Because my engine is an automatic i need a flywheel, which will fit.
Which clutch I should use, 26 Spline input shaft and is good fore my powerlevel?
Which yoke must be used 31 Spline output shaft.
And also very important which gears i should use in the rear axle 3.71 or 4.11
Regards Joerg
Old Dec 18, 2013 | 03:13 AM
SRV8's Avatar
Anyone ?
Old Dec 18, 2013 | 03:48 AM
2X72's Avatar
Just be aware you are going to have to cut a big chunk of your tunnel out to get that to fit. I don't know about your other questions.
Old Dec 18, 2013 | 04:17 AM
allyolds68's Avatar
The search function sucks here but I found this thread in a Google search:
https://classicoldsmobile.com/forums...html?styleid=1
I'm pretty sure Aceshigh ended up changing to an LS1 so I doubt he carried this idea through. You may have more luck on the Pontiac forums (http://forums.performanceyears.com/forums/) because those guys tend to spend a lot more money than us cheap Olds guys.
Old Dec 18, 2013 | 11:17 AM
citcapp's Avatar
Contact these guys. They can set you up with the whole deal, for connecting to to your 455. I used them on MY TKO 600 behind my 455 in my 48 Olds
http://www.hurst-drivelines.com/?page_id=155
woodie582
32
Sep 29, 2013 07:28 PM
1971 442 convert
Jul 24, 2013 09:18 AM
OldsMotion
Apr 12, 2013 03:45 PM
cwracer
Jan 30, 2013 02:34 PM
MN71W30
Drivetrain/Differentials
Jan 15, 2011 10:12 PM
