1968 442 crossmember removal….its stuck...
Old Nov 18, 2014 | 11:02 PM
shamusj's Avatar
This may sound like a really moronic question- I'm prepping to remove the original 400 g with T400 transmission. Everything went really well until it came to removing the crossmember- its unbolted, loose yet I'm not sure how to get this thing out. Am I missing something ?
I've worked on many cutlass and 442s over the years and don't recall it being this big of a PIA.
Any guidance or ideas would be appreciated. Thanks- Mike.
Old Nov 19, 2014 | 03:24 AM
Yellowstatue's Avatar
If the exhaust pipes are out, then rotate the crossmember, one side forward and the other rearward. Usually the trans mount gets in the way. Might have to remove it also.
Old Nov 19, 2014 | 05:53 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Vert or coupe?
Old Nov 19, 2014 | 06:57 AM
shamusj's Avatar
THanks for the responses- I was up late trying to make some progress and the of course the very last thing on my list puts up a good fight.
I'll remove the tranny mount and see if that makes a difference (good input)….it almost looked like the member was pinching in between the body and frame. If I need to beat it out I'll try that.
It's a convertible.
Thanks again for the support.
My '67 E motor is all built and ready to drop in…just need to get this ugly motor trans out to make room. Everything I've looked at seems to show that the motor has never been out- car was sitting dead w/blown head gasket since '86 so I guess thats possible.
Installing an AC delete box, a little paint, some new bushings/springs and then start putting her back together.
Old Nov 19, 2014 | 07:39 AM
pogo69's Avatar
morgan
the trans mount should come out to make it easier... sometimes over the years if a car has been jacked up a lot and put on stands on the front part of the frame it may get a slight bend in the frame channel so you may have to convince it with a hammer a bit to get the crossmember as far forward on one side and as far back on the other and tilt it. it will go back in easier though
Old Nov 19, 2014 | 08:38 AM
shamusj's Avatar
Hey Guys- I must have had late night fog in the brain. I removed the tranny mount and crossmember came right out. Sorry for the dumb question!
Old motor and tranny will be out this weekend- hopefully new motor in over Thanksgiving.
Thanks again for the support- Mike
Old Nov 19, 2014 | 09:36 AM
Octania's Avatar
Others can learn from your inquiry- no need to apologize for the questions!
Old Nov 19, 2014 | 10:53 AM
moved to electrical thread
Last edited by droldsmorland; Nov 19, 2014 at 02:21 PM. Reason: please the weenies
Old Nov 19, 2014 | 11:37 AM
pogo69's Avatar
morgan
Reason I asked is it seams the 68 Z cars with AC only have one of the horn type relays mounted under the hood. The one on the drivers side which all cars have AC or not which is the horn relay. All the other AC cars have two of these in plain view. One in the normal spot and the AC relay on the passenger side fender in about the same location as the drivers. Just spotted this difference recently so I have not looked to see where the Z cars have their AC relay mounted.
what does the horn/ac relay have to do with the trans. crossmember?
Old Nov 21, 2014 | 12:18 AM
shamusj's Avatar
Truly amazing what one can accomplish when both the 7 year old and the 3 year old go to bed early…...
Old Nov 21, 2014 | 07:16 PM
sammy's Avatar
Sammy70 455 Supreme
Good stuff!....looking forward to pics of new motor in the car....
Old Nov 21, 2014 | 09:07 PM
z11375ss's Avatar
Senior Moment Member
Your wife must be pretty cool. Mine needs to park in the garage.
Octania
May 16, 2015 07:52 AM
navvet
Jan 5, 2014 01:51 PM
1956OldsDarrin
Jan 23, 2011 12:11 PM
woodie582
Jul 21, 2008 05:53 AM
jkt660
Dec 7, 2007 03:38 PM
