1968 442 TH400 crossmember location- aftmost
feller needed to know the trans crossmember location for the '68 442 with TH400 so I looked at the red car. There are about 7 holes in the frame. Two empty between XM bolts.
So, 3-4 possible positions.
Turns out, the AFT MOST hole in frame used the aft hole in the XMember
here is a pic of his frame with XMember installed. Must be the RH frame rail, viewed from above.
russroyce
Aug 27, 2014 05:27 AM
halfmoontrail
Jan 7, 2013 05:54 AM
