Bad transmission or torque converter?
Old Jun 6, 2014 | 09:04 PM
mfpm7232's Avatar
I've noticed that my car's transmission seems to be acting up a bit more lately and I'm interested in hearing your thoughts on what might be the cause. The car is a bone stock 69 Cutlass with a 350 / turbo 350.
When the car is cold, it has no problems shifting or driving. Once up to temp (and especially on hot days) it seems to slip a bit off the line. As a result, I'm very easy on it until it hooks and then I can put my foot into it more if I want/need to. I drive it like Grandma most of the time.
I also noticed that when shifting to park and then back to drive, when hot it seems to take it's time engaging. On a couple of really hot days I've actually had to shut her down and wait a bit for it to cool. The car does not have a transmission cooler.
The tranny fluid and filter were changed last summer and the fluid seemed fine. No apparent issues.
So my question is, does the issue sound more like a problem with the converter or with the tranny? Regardless, I was thinking of installing a cooler anyway so should I just try it to see if the problem goes away?
The longer term plan was for a tranny overhaul with a shift kit for crisper shifts and a 2500 stall. I'd match that up with future plans for a new rear end and some engine mods. So I'm not too worried if the tranny overhaul is the ultimate solution either.
Looking forward to hearing from the experts out there.
Cheers,
Mark
Old Jun 6, 2014 | 09:11 PM
Check the fluid level warmed up with the engine running and in park. If it's not low, then you need to get it checked out. It probably is the trans.
Old Jun 7, 2014 | 02:02 PM
Transman's Avatar
Sounds to me like that transmission is about to fail. Time to find a good transmission shop in your area.
Transman
Old Jun 9, 2014 | 09:12 PM
mfpm7232's Avatar
Thanks guys. I've checked the fluid and it looks good so I guess it's time to look around for a transmission overhaul...
Old Jul 23, 2014 | 07:55 PM
johnnyjaws's Avatar
I would do a band adjustment 1st that's what it sounds like to me
Old Jul 23, 2014 | 08:14 PM
Magna86's Avatar
Time to add a trans cooler too!
Old Jul 23, 2014 | 08:16 PM
coppercutlass's Avatar
Chevy budget Olds powered
The th350 has a non adjustable band.
Old Jul 23, 2014 | 08:33 PM
johnnyjaws's Avatar
ok didn't relize that been working on a lot of dodges lateiy
jensenracing77
Jun 25, 2016 02:20 PM
GINCSC
Mar 11, 2015 02:20 PM
Stevec
Apr 20, 2012 05:46 AM
oldsy
Jun 23, 2011 06:37 PM
Surfrat67
May 14, 2006 03:42 PM
